Maintenance Minder Reset
Old 04-22-2006, 08:50 AM
7th Gear
SWeeTDaDDi's Avatar
I have a 2005 RL. The 'B2' service reminder is on in the display and it shows 5% left to an oil change. I don't live near a dealer and won't we able to get the service done for about 1,000 miles. This 'B2' reminder and/or the 'i' showing up in the display drives me nuts driving night. The owner's manual tells me how to reset the minder but I can't get it to work. I turn on the ignition, the 'B2' shows up. I press and hold the Sel/Reset and nothing happens. On another forum it says it may have to do with my lights being set to auto on. I turned that off too. There must be a simple soultion to this irritation. Can anyone help?
Old 04-22-2006, 10:09 AM
1HOT NSX's Avatar
I can only think that you may not be holding down the SEL/RESET button long enough. You should hold it down for at least 10 seconds. You also need to have the oil life minder on the screen at the time you push the button. All of this is on page 294 of the owner's manual. Good luck.
Old 04-22-2006, 11:20 AM
7th Gear
SWeeTDaDDi's Avatar
I got it. The key was the oil life minder must be displayed before pressing the SEL/RESET. I was pressing it when the screen said SERVICE B2. Thanks 1HOT NSX
Old 04-22-2006, 04:13 PM
SodaLuvr's Avatar
You ought to do the service before resetting it...
Drive to Jiffy Lube with a Napa Gold or Purolator PureOne oil filter pre-purchased from Napa or Advanced Auto, respectively, and have them change the oil/filter, rotate the tires, and replace the engine and cabin air filters. I bet it'll be less than $200, much less that what the dealership will charge you.
Resetting the Maintenance Minder system without completing the service a
Old 04-22-2006, 09:22 PM
7th Gear
SWeeTDaDDi's Avatar
Where I live the closest Acura dealer is 650km south of here. Thats why I needed the AWD. As for Jiffy, Napa or Purolator...we just have a Canadian Tire. As soon as I get a few days off to visit civiliazation I'll get Acura to do it.
Old 04-22-2006, 09:38 PM
SodaLuvr's Avatar
DELETED
08_UA7_Gr33k
02-11-2016 02:17 PM
LeVeL
10-18-2015 04:19 PM
brboy
10-05-2015 11:34 AM
Froid
09-27-2015 06:16 PM
ceb
ILX
09-27-2015 10:56 AM
Quick Reply: Maintenance Minder Reset
