H-006: coolant and brake fluid changes
ok, now I continue with my maintenance! Any tricks to changing the anti-freeze? Where is the best place to drain it from? Just pull a hose from the bottom of the radiator, or is there a drain plug on the block?
As for brakes, when have you guys changed the brake fluid--time and mileage please. Also DOT 3 or 4?
Thanks gentlemen!
Acurod
Thanks gentlemen!
Acurod
DOT 3 is the recommended brake fluid. From the manual
Replace the brake fluid every 3 years,
independent of mileage.
Always use Honda Heavy Duty
Brake Fluid DOT 3. If it is not
available, you should use only DOT 3
or DOT 4 fluid, from a sealed
container, as a temporary
replacement.
Using any non-Honda brake fluid can
cause corrosion and decrease the life
of the system. Have the brake
system flushed and refilled with
Honda Heavy Duty Brake Fluid
DOT 3 as soon as possible.
Brake fluid marked DOT 5 is not
compatible with your vehicle’s
braking system and can cause
extensive damage.
replacement.
extensive damage.
SidhuSaaB
05-30-2020 12:40 AM
lanechanger
10-13-2015 10:56 AM
Username 0
2G TSX Performance Parts & Modifications
23
09-28-2015 09:09 AM
