Found a good set of plug and play LED DRL's for our cars
Hey guys, thought I would share since throughout my search for a set of LED DRL's for my car, I wasn't really finding much recent information on a good set of lights. A while back it seems people were using VLED but it looks like they discontinued the type we needed. But, I went out on a limb and bought these Simdevanma 9005/HB3 bulbs off of Amazon for $40 that I found one forum member recommend. I can confirm that they work perfectly and are 100% plug and play. My high beams still work and no error codes. Here's a pic, again I just thought I'd share. The passenger side looks brighter for whatever reason in this pic because they were flickering in my camera, I promise its not like that in person. If you're looking for some LED DRL's for your car check out Simdevanma
HEAVY_RL (06-29-2018)
Thank you, LS1SSChris. I've been interested, in installing DRLs on my 03 TLS, for some time. I'll check these out.
If you don't have codes, and it actually has two levels of brightness (DRL <--> High Beam), then it's a steal.
The Amazon bulb I got in 2006 threw codes, and had only one level of brightness.
The VLEDs I'm sporting now have been perfect. No codes, DRL is not too bright, and highs are nice and bright.
Here is a screen shot of the order confirmation from last year. Spendy, but totally worth it. Car looks so much better with LED DRLs.
What was the lumens and wattage you got? Does it match the low beams color as well?
7600 lumen and I believe its 60 watt. They are ever so slightly more white than the low beams but I still think it looks pretty good. Just put a set in my friends TL type s and they work perfectly in his car as well
kcjohnnyboy (07-10-2018)
How is the high beam visibility at night as compared to stock 9005 bulbs?
Thanks!!!
Great thanks for confirming guys!!
any suggestions if something similar is available for fog lights? I like the plug n play factor, and if there are LEDs I can pop in into fog light housing, that’d be awesome!!!
Check out OPT7 for the fogs, I have the CREE V2 LED's in my car, I bought the white color and they match the low beams almost perfectly. They are only $30, I've had them in for several months now and no issues
I am still debating should I go for some other LED DRL/High beams, or may try another pair...
Received bulbs today, and after installing one - all good... Installed the other one, "Check DRL system" ... So returning them back to Amazon. Another thing I noticed was that these run really hot... When you touch heatsink it is really hot to the touch after working for 5 minutes... I kind of anticipated it since there was a little fan behind, but not sure how these how ld up on long term...
I will do some more research on reviews as well just to see - temperature is also another thing to consider... these were running pretty hot definitely do not want to get my car burnt down because of some chinese led bulbs
I have had the same ones in my car for a few months now and drive 3 hours a day between work and other stuff with the DRL on and have no heat effects or any issue with excessive heat at all
Oh, one more thing since I just noticed you have a CGP like me...have you purchased any touch up paint for yours? The paint code on my door comes up as "Graphite Pearl" instead of CGP. I'm guessing they just renamed it? Or used a different name for that color on Honda vs. Acura?
RoeLarry (07-26-2018)
I decided to go with the newer gen led bulbs that have fanless heatsink which I am more comfortable with. I should get them tomorrow and will report back how all goes. I think I went with beamtech, 50W or something like that ...
In the case these do not work I will go with https://www.superbrightleds.com/ ... they ffer lifetime warranty, and are only 10-20$ more expensive.
In the meantime I got cree fog lights I installed yesterday... al I can say YES, I CAN USE MY FOG LIGHTS NOW!!!
HEAVY_RL (07-27-2018)
Here are the fog lights comparison halogen to below:
Alla Lighting Xtreme Super Bright H11 LED Fog Lights High Power 80W w/Projector (Set of 2) https://www.amazon.com/dp/B07CZQ7WVF/ref=cm_sw_r_cp_apa_X1YwBb5B23714
Tried Beamtech - no go, got Check DRL System message. Sending back to Amazon... One last chance I am giving to DRLs recommended here as they do list correct wattage (60W)... If that does not work, I will probably go with some other pair I find it guarantees working with our RLs.
These are the best IMO... but the price is triple...
https://www.diodedynamics.com/led-he...plate-190.html
Now, the issue I am facing is... there is a message in my navi showing the envelope... if I read it, it stays unread... if I try to delete it (via menu cancel and guide hold for 5 sec), it simply won’t delete the damn thing...
DRL work just fine, but I cannot believe that unplugging and plugging bulbs back would cause issue like that... I have never seen this before...
i tried to disconnect negative battery terminal and leave it for 15 minutes... after connecting it, message comes back... so what gives!!??!?? Anyone? Is trip to the dealer imminent?
DRL navi msg - cannot delete in diagnostic screen (!?!)
The issue I am facing is:
I swapped old halogen 9005 bulbs (sylvania) with LEDs other member reported working plug n play route... got Check DRL system, so not plug n play as it was claimed. I replugged back in my halogen sylvania bulbs, started car and now there is a message in my navi showing the envelope... Daylight Running Lights not working... if I read it, it stays unread... if I try to delete it (via menu cancel and guide hold for 5 sec), it simply won’t delete the damn thing...
I tried to disconnect negative battery terminal and leave it for 15 minutes... after connecting it, message comes back... so what gives!!??!?? Anyone? Is trip to the dealer imminent?
Saga just got more interesting... ordered Simdevanma or whatever the brand name is, got second pair today, popped them in... same exact damn message “Check DRL System” ... packed it all back up and sending back to amazon. These come in marked as 28W... i contacted the support via email, they are explaining two bulbs make 60W! But apparently these are not an oem match considering light comes on on my mid screen.
I am thinking of getting the JDM_kit (resistors) and installing that... but if I do, and message is still there (not on MID screen but only NAVI) I would be back at the square one. So I will take it to the dealer and see what they find. Will update here.
I was able to correct this issue by ejecting NAVI DVD and inserting it back... looks like something got confused... to share other troubleshooting steps is probably not needed so I can save time and share what fixed it lol ... lost at least an hour of trying to plug and play different bulbs thinking that was the culprit lol...
MOD - feel free to merge this thread if you'd like with another similar one or close it. This is where I found suggested fix:
https://acurazine.com/forums/2g-rl-a...ssages-499260/
