70K service?
70K service?
I can't seem to find the info and I apologize for the likely redundant question.
Is there a 70K service requiring a flush/change of tranny fluid or something?
I love this RL, more important, so does my DW who drives it!
Hope to add a RLX Hybrid to the garage soon
I had already reviewed that but, found it confusing that it seems to indicate up to 160K miles for flushes and I thought I'd read here some time ago to have something flushed at roughly 70-80K miles?
You have the following fluids to keep track of on the car:
-Engine oil
-transmission fluid
-front differential
-rear differential(2 chambers)
-brake fluid
-engine coolant
Hope that clears that up! The maintenance minder, to me at least, was designed for the original owners who were more that likely " drop it off at the dealer" when the minder comes on... The numbers after the letters also code for something.
-Engine oil
-transmission fluid
-front differential
-brake fluid
-engine coolant
-Engine oil
-transmission fluid
-front differential
-brake fluid
-engine coolant
-Engine oil
-transmission fluid
-front differential
-brake fluid
-engine coolant
-Engine oil (interval depends on oil used, however manual states 7500 miles)
-transmission fluid (45k miles per manual)
-front differential (30k miles)
-rear differential(2 chambers) (30k miles)
-brake fluid(don't remember the mileage interval)
-engine coolant (60k for the first change then every 30k thereafter)
I added in miles to my prior post, hope that answers that.
stagefoursurvivor (03-27-2017)
45K on the tranny & 3 differentials?
Not sure what 3X3 is for 15K?
Thanks, guess I need to do the tranny & 3 differentials since I can't be sure what was done prior to my purchase at 51K.
I appreciate your valuable guidance
projektvertx (03-27-2017)
45k on the transmission would be the 3x3. In a nutshell, you would drain the fluid out of the transmission, refill it, drive it thru all gears. Repeat the process two more times. The idea behind this is that you're draining a good chunk of fluid out of the transmission that way. The alternative that floats around here would be changing the transmission fluid once every 15k.
I likely need to have it done by a shop, bad leg prevents climbing around the car these days but, grateful I'm not taking a dirt nap!
I haven't seen any suggested alternatives for the differential since I've been here. I get it, my dad has gotten to the point where he doesn't have the time or the physical capacity to maintain his car on his own anymore. He says the same thing, I'm still alive so it's fine
My almost 12 yo wagon, my baby since new, has to go, 5sp stick doesn't work well with a ghimpy leg. Hope to replace her with a RLX Hybrid soon.
I keep my cars a long time, maintenance & care is the key...no shortcuts.
Thanks everyone.
Appt Monday for rear flush, oil/filter, WW inserts $135 + tax BUT, tranny flush/change they hesitated on until they check the car.
Can they tell by examining the fluid, will they try to jack the price to add this? What's a reasonable charge? I'm skeptical they'll say I need some super duty fluid for $300 additional!
Transmission fluid flush vs drain
Having spent the last few days scouring the net, I have no clear direction on which should be done tomorrow, simply drain & add more Honda fluid or flush the system 3X3... and perhaps change out the filter?
Everything I've found conflicts, "don't do the flush, not recommended", "if you do a drain & top-off, you simply contaminate the new fluid with residual in the old"...These comments are 99% from Honda owners/techs but, presumably apply to my RL.
It's scheduled at a Honda dealer and I want to be prepared, also a reasonable price to pay depending on the method. Yeah, if I could physically do it, I would, just out of the question right now.
If you were doing it yourself I'd tell you to drain and refill 3quarts every oil change.. but since your getting it done at the dealer I don't see how you even have a choice? The dealer doesn't normally do out of normal procedures like a 3x3 drain/refill.. not sure why you're even asking here considering the people doing the work are already telling you their recommendations..
My inquiry is to determine which is the best to request on arrival.
I'm sure you INTENDED to be helpful
Their statement is correct and thats the reason for the 3x3. The expectation is by the 3rd effort you will have exchanged all the old fluid with new fluid. If its a Honda dealer I would question IF they actually used the term "flush" as I dont think thats what their machine does due to how fragile the transmissions are. As to price I will let someone else comment on that I dont have any experience there.
Since I don't KNOW what's been done in the past and WHICH alternative may be offered, or none, when I walk up to the desk, I'll need to make an on-the-spot decision.
I'd expect to pay substantially more for 3X3 and that's acceptable if that's the best long term decision. It's the value of the car & reliability, the $$ is secondary
Thanks everyone.
stagefoursurvivor,
The drain/flush and exchange service on transmissions is a service provided by my local Acura dealer in Honolulu. They drain 3 quarts, refill/replace, then run the transmission thru the gears before repeating the process 3 times. Locally, this service costs $217.
Being a mechanically minded guy, I decided to do the job myself. Well, let me say, I may have made a mistake for several reasons.
First, finding the right drain plug is a challenge. When I removed the drain plug that the parts guy had told about, no oil came out. This plug is located on the driver's side of the transmission case next to the half shaft.
Second, since there are several drain plugs on the lower surfaces of the transmission case. I selected one and removed the plug. By the time I realized this was gear lube draining rather than transmission fluid approximately one pint had drained out. Now I need to get to the dealer for some gear lube.
Third, still haven't found an appropriate drain source after an hour of searching, so may decide to toss in the towel, replace the gear lube, and let the dealer do the job.
Good luck!
Second, the drain plug
Good luck!
stagefoursurvivor,
Good luck!
Good luck!
Today went well, offered me straight drain of tranny or flush but, immediately stated using a conditioner with flush...NOPE! just drain & replace.
Rear differential change, lube, oil, filter, wiper inserts $211+ tax
I'm a happy camper and on top of DWs wheels!
projektvertx (04-04-2017)
