FOB dead after battery replacement
Old 03-21-2017, 08:08 PM
FishX's Avatar
The messager that battery was low on my FOB showed up on dashboar ... . Bought new 2032 CR battery, replaced it and now FOB is dead i.e. car
does not reponds . Are there an additional steps to pair with the car ? Should I give another battery a try ...?
Old 03-21-2017, 08:38 PM
vbgregg's Avatar
Did you put the battery in the correct way, or might it be in backwards?
Did you remove the little protective sticker from the battery?
Old 03-21-2017, 08:42 PM
RDX-Rick's Avatar
What model year is your RDX?.
  • Do the doors unlock when you reach behind the door handles (i.e. FOB still in your pocket).
  • Does the FOB unlock your doors (including the hatch) from a distance when you use the unlock-lock-hatch buttons on the FOB?.
  • Do any LED's light up on the FOB when you press a button?.
If none of these things are happening, especially the LED's not lighting, then
  • your new battery is probably dead
  • your battery is installed backwards
  • your FOB is defective
If these things do work, then perhaps it's just your ignition sensor that is defective. Does the second key work normally with the ignition?
Old 03-22-2017, 11:53 AM
2014 RDX AWD Tech
Comfy's Avatar
Also try putting in your old battery. It should still work with the warning message that battery is low. Why don't you buy a new battery (from a different shop) and give it a try? It's only a few dollars. All batteries have a limited shelf life whether used or not. It's very unusual for a keyfob to simply malfunction (though not impossible). Let us know what happens.
Old 04-09-2017, 01:08 PM
OriginalLucy's Avatar
I did the same thing and the new battery was dead. Tried a different one and all good. Some of those made in China batteries are pretty unreliable
Old 04-10-2017, 07:56 PM
Starflyer's Avatar
I just went to my dealer and they replaced the battery for free...
Old 04-12-2017, 10:46 AM
It was just pining for the fjords.
