Front rotors heating up...
2014 RDX AWD Tech
After driving around for a while I returned home and found that the front rims are warm to touch. I checked the front rotors, they are so hot as to even burn my fingers. The rear rotors are just warm. Is this normal to be like this? I mean the front rotors to heat up so much in regular driving. There was no loss of breaking power or burning smell. Why the difference from front to rear. Thanks in advance.
Stay Out Of the Left Lane
Received 1,236 Likes
Front brakes typically do most of the braking and this is why you typically see brake dust all over your front rims. Unless you have seen a drop in MPG or something else to indicate the calipers might be dragging, I think you are okay.
Every car I have owned the front brakes and wheels get warm, the act of stopping/braking is caused by friction and frictions generates heat. You are bring a vehicles in excess of 3500 lbs to a stop, basic physics. That is why hybrids us regenerative braking, recover that energy in the form of electricity to recharge the battery.
I noticed that after my rear rotors got water sprayed on from the sprinkler overnight,then rusted the next day that it took about a week of driving for the rust to be braked-off.
To me,that pretty much shows the bias they have built in.
When there is no traffic behind me,I have gone to using the paddle shifter (when in D), to gradually drop down the gears from 6th to 2nd,so it really saves the brakes.My brother who owns a tranny shop said it doesn't hurt this tranny doing it.I was worried that it might wear it out.I just don't do it when in traffic,since the person behind does not see the brakelights being used,yet I'm gradually slowing down,so I'm afraid they could rear end me.It's a neat feature I think,especially going down a long exit from the freeway.
When there is no traffic behind me,I have gone to using the paddle shifter (when in D), to gradually drop down the gears from 6th to 2nd,so it really saves the brakes.My brother who owns a tranny shop said it doesn't hurt this tranny doing it. I was worried that it might wear it out.
My front pads wear faster in my 08 RDX for sure. Just replaced the fronts at 45K miles while the rears still have lots of life left.
Using the trans clutches to *brake* your vehicle, wears the trans clutches, just like heavy throttle up-shifts does (more than normal). And the trans clutches have only a limited life, just like a manual trans clutch.
I wonder if the MID is smart enough to notice your non-normal downshifting, and will generate a shorter than average request for trans service (oil change)???
Yes, it does. Mechanics (and shop owners) are not engineers - they may have *repair* (parts replacement) skills, but generally have no clue as to how things really work.
The thought is that it might be better to sacrifice a bit of tranny life for your life.
when you brake, most of the weight is transferred to the front wheels, thus the brakes are larger and heat up more than the rears as they are turning absorbed energy into heat.
Engine braking should only be used in an emergency (where you need to shorten up your stopping distance to prevent hitting something), slowing down while traveling down hill where you are in danger of overheating your brakes (fade), and sometimes when towing.
If all you are doing is coming to a stop, lifting off of the throttle gently and letting the car coast before braking is your best bet. It also returns the best fuel economy for the car.
rockyboy
12-06-2022 02:29 PM
asahrts
09-04-2015 05:55 PM
