XS-P Headers
Old 04-03-2017, 08:24 AM
mattcl-s's Avatar
XS-P Headers
Ordered the XS power headers last night will be my second power mod Just wondering on a scale 1-10 how difficult is it getting the rear manifold off?
Old 04-03-2017, 09:55 AM
mattcl-s's Avatar
would it be easier to loose the rear manifold bolts through the top or bottom which is the best angle?
Old 04-03-2017, 01:07 PM
mattcl-s's Avatar
Asking anyone who has installed these before how long did it take?
Old 04-03-2017, 01:36 PM
johnboy1313's Avatar
I had the engine out when I installed mine. Sorry can't help.
mattcl-s (04-03-2017)
Old 04-03-2017, 03:04 PM
Unregistered Member
Karanx7's Avatar
It's not too bad. I did almost everything from under the car.
Old 04-03-2017, 08:41 PM
M90booosted
03-6/6's Avatar
did mine in car. rear isnt bad. need a long extension to get a couple of the lower bolts. you can get most from the top though. make sure you leave it all loose and bolt down pipe on then tighten the manifolds to heads. mine didnt quite line up but i kinda forced it together and it got positioned into place.
mattcl-s (04-04-2017)
Old 04-04-2017, 07:58 AM
mattcl-s's Avatar
thank you! that's the response I was looking for
Old 04-04-2017, 09:24 AM
3.5 psi
gnuts's Avatar
get some PB blaster on the bolts prior as well.
Old 04-04-2017, 10:02 AM
mattcl-s's Avatar
got it on the front bolts last night couldn't really get in there with the PB on the rear ones
Old 04-08-2017, 06:59 PM
mattcl-s's Avatar
Had no idea these would be shipping from China! I read another thread on here but cant seem to find it but someone was saying I should use different hardware for the bolts cause their cheap, does anyone know the size? I should have them on Tuesday
Old 04-09-2017, 03:27 AM
Unregistered Member
Karanx7's Avatar
You can use the supplied stuff. They're just bolts and nuts.
Old 04-09-2017, 11:39 AM
RooEng's Avatar
I bought mine years ago and the bolts that came with it were a size smaller in diameter than the holes in the collector flange. Like a 8mm bolt for a 10mm hole. It's been too long ago to remember what size they were but I had some in my box of extra bolts that fit perfect. If yours fit right, there's no reason not to use them.
mattcl-s (04-10-2017)
Old 04-09-2017, 12:24 PM
thisaznboi88's Avatar
might want to go to honda and pick up the correct nut and bolts for the headers. It would suck if a stud or bolt broke in the cylinder head.
Old 04-09-2017, 02:25 PM
Unregistered Member
Karanx7's Avatar
No they use the same head studs. The bolts and nuts connect the collectors to the j-pipe, which are completely different from the OEM setup that uses studs.
thisaznboi88 (04-09-2017)
Old 04-09-2017, 06:29 PM
M90booosted
03-6/6's Avatar
i used the supplied hardware. no issues on initial install, but after some miles and an engine swap 2 broke. no big deal though.
Old 04-10-2017, 07:28 AM
mattcl-s's Avatar
Get 6 good grade 8 bolts like stated above (10x40 works as well) and have a less than 5 dollar piece of mind-- fsttyms1
for some reason I cant paste the thread on here but some people also said they had no problem using the supplied hardware
Old 04-10-2017, 06:58 PM
M90booosted
03-6/6's Avatar
i just used what i had at home. still holding fine so far.
Old 04-11-2017, 08:54 AM
mattcl-s's Avatar
Ok I just have been reading some mixed reviews about them so maybe it was just a not proper install with them
Old 04-11-2017, 03:02 PM
I Wanna Beer
TheWeez's Avatar
They're not the same hardness as the factory bolts. The factory bolts are a couple dollars. It's worth the investment as is going and buying the factory gasket instead of the garbage one included.
Old 04-11-2017, 04:56 PM
Unregistered Member
Karanx7's Avatar
Like I said previously, you can't use the factory bolts for aftermarket headers. The OEM exhaust manifold has studs that thread into one side, but aftermarket headers don't have those threads.
Old 04-11-2017, 06:00 PM
there is always fastenal
Old 04-12-2017, 08:20 AM
mattcl-s's Avatar
I got the headers in yesterday I will be installing them this Friday
Old 04-12-2017, 08:22 AM
mattcl-s's Avatar
so I know there is no using the factory bolts should I just use the ones that came with the headers? also which gasket should go with OEM or the new one with the headers?
Old 04-12-2017, 01:06 PM
Unregistered Member
Karanx7's Avatar
Dude, just use the stuff that came with the headers.
Old 04-12-2017, 01:53 PM
mattcl-s's Avatar
Ok
Old 04-14-2017, 07:29 PM
M90booosted
03-6/6's Avatar
this. its gonna be ok to use china stuff.
Old 04-15-2017, 01:00 PM
mattcl-s's Avatar
NO! Not ok to use china hardware
Old 04-15-2017, 01:20 PM
mattcl-s's Avatar
First thing i am going to say is whoever thinks using the china crap hardware is a moron! whoever reads this and wants to install headers on their car GO GET NEW HARDWARE! so after about 6 hours i got em installed and it is a 2 person job cant do this by yourself. The part that took us so long I stripped a rear heat shield bolt and after trying to get it off with a gator grip socket(which is a piece of junk) it just rounded it even more so last resort was to cut it off with a dremel. after that everything was a breeze. now putting everything back together was simple just retrace your steps and keep everything loose until it all bolt have been put back in and then tighten everything back up. oh and if you can spray PB blaster on everything its a time saver! After getting everything back installed of course had to taker the car for a rip first thing i noticed it is more of a linier modification not something that will throw back in your seat but i cant feel a difference in acceleration so i am happy with this mod just wish i should have went with my instinct and got new hardware
thisaznboi88 (04-15-2017)
Old 04-15-2017, 01:54 PM
yay vtec now I gotta install this on my pilot along with RL camshaft and camshaft spacer for the j35a4
Old 04-15-2017, 11:23 PM
lateralus's Avatar
gives the motor some extra roar to the sound as well.
Old 04-16-2017, 08:57 PM
M90booosted
03-6/6's Avatar
nothing wrong with hardware once again. also, you can do it solo. ive done it before a few times.
Old 04-17-2017, 08:49 AM
Jonathan Hill's Avatar
are you 6speed? headers are next on my list and im going to try to not spend an arm and a leg?
Old 04-17-2017, 11:56 AM
mattcl-s's Avatar
yeah 6 speed It was 260$ well spent
Old 04-17-2017, 04:11 PM
these used to be 130 shipped
Must be a decent product if the pricetag has doubled in the past few years.....I see Manzo headers on ebay for 130 shipped but will they fit the 6 speed? .....and anyone know how the quality is?and for twice the cost id probably get the tried n true (xspower) anyways.
Old 04-18-2017, 03:31 AM
lateralus's Avatar
the manzo ones fit has the bend for the rear mount... they honestly probably the same headers as the xs power/s-rs etc etc..
Old 04-19-2017, 06:31 AM
Former Sponsor
rondog's Avatar
I remember getting OBX headers back in the day. You're gonna need a supercharger after this if you want any more power that significant enough to feel from the seat of the car.
Old 04-19-2017, 06:43 AM
yeah i found obx headers for around 400$. they look a little better but is it worth the extra $? doubt it. lol i already want a sulercharger....just dont want to have to mess with tuning etc etc.....so 4" intake and headers for now....
Old 05-10-2017, 10:11 AM
I did it by myself.
Old 05-10-2017, 10:14 AM
I just installed the manzo headers this week. The supplied gaskets don't fit. The grooves in the down pipe for the gasket are smaller than the gasket. The OEM Honda gaskets don't fit either. They're too small to fit in the grooves. They do fit with the six speed in my odyssey though. I'm more than likely going to pull these for better quality headers in the future. For now, I just want to get it on the road.
Old 05-10-2017, 01:00 PM
I bought DC headers on ebay for 265, just worrying about them cracking.
