ticking sound when idle??... timing belt recall??
Old 11-05-2004, 03:35 PM
skim's Avatar
when i'm sitting in idle, i can hear this ticking noise going off in the engine bay, only when idle. when i gas it its gone. it sounds like the timing belt is "squeaking" or something. i remember a recall for the timing belt awhile back. could this have anytihng to do with it?? is it even dangerous at all? i hate bringin the car in for just checkups like this. anyone know??
Old 11-05-2004, 04:03 PM
Masshole
mc_yanzo's Avatar
There are a bunch of people, including myself, who have had this problem. If it is the same thing that I am hearing, then it is not the timing belt. It is some kind of valve in the air intake. It is normal and there is nothing you can/should do about it.
Here's a related thread:
https://acurazine.com/forums/showthread.php?t=157962
Old 09-29-2018, 07:57 AM
Andy Keller's Avatar
Ticking noise
hey I had the same ticking noise, it increased with RPMs sounded to be coming from rear of the motor, it turned out to be the rear camshaft was bad and I work I Honda so I took it there and they said it’s common problem in this generation (2012) they replaced rear camshaft and rocker arms and ticking is gone, for it to be fully diagnosed it had to be torn apart, only cost 60$ for them to tear the motor down to the point of breakdown since I’m an employee at the factory.
vaughanml2
11-01-2021 10:16 AM
redsox68
09-16-2015 06:18 PM
merc009
09-14-2015 06:43 PM
asahrts
09-04-2015 05:55 PM
Quick Reply: ticking sound when idle??... timing belt recall??
