Polishing intake manifold
Old 07-20-2017, 12:54 PM
mattcl-s's Avatar
If I wanted to polish just my intake manifold would it even be worth the time? I don't want to do any port matching and all that if I could get some gains from just doing the manifold ill stick with that also, not going for a MIRROR look finish either but if I can smooth out the cast marks and make it smoother inside might do that when I install the MDX spacer soon
let me know what you guys think
Old 07-20-2017, 01:01 PM
mattcl-s's Avatar
not sure if this will get much attention but that's ok with me and It might seem sort of out of the box to why I would just only do the manifold
Old 07-20-2017, 01:23 PM
Received 16,260 Likes on 11,971 Posts
i'm running a DIY intake manifold that some one ported and polished... I do not know how well they perform but at least i can say it's polished.
mattcl-s (07-20-2017)
Old 07-20-2017, 01:28 PM
came in this UGLY blue paint, and i had to spend time grinding the paint off.
i dont have any pictures of the ports...but they were a tiny bit larger than my stock one.
IT did come with a larger diameter throttle body, that some one bored!
Old 07-20-2017, 02:03 PM
3.5 psi
gnuts's Avatar
I think only a dyno would prove any gains as it's probably in the 5whp range from porting a manifold and runners, so nothing you would feel that much. If you have the time, I would smooth out the casting marks and gasket match the openings. Just flip the manifold upside down and place the gasket in it's proper place. You can scribe a line or use marker to draw on the area that will need to be removed. It's super easy and you just need a rotary tool with different grit wheels. I didn't go mirror finish either.
The following 2 users liked this post by gnuts:
justnspace (07-20-2017), mattcl-s (07-20-2017)
Old 07-20-2017, 02:08 PM
mattcl-s's Avatar
That is exactly what I want to do! did you take the plenums off as well? im thinking since I polished the mdx spacer ports using an 80 grit flap wheel and a 120 grit that should do the trick right?
Old 07-20-2017, 02:16 PM
mattcl-s's Avatar
never mind it looks like you did that
Old 07-20-2017, 07:03 PM
typeR's Avatar
i spent days doing mine to a mirror finish ,,, sure it wasnt much but was the second 3.5L swap ever and had every other bolt on including had my TB done by king ... havent kept up much but 13.306 @105.83 i think is still an all motor best ?
mattcl-s (07-21-2017)
Old 07-20-2017, 09:22 PM
Unregistered Member
Karanx7's Avatar
Welcome to AZine.
You should post some pics. Unless of course, you're a liar... Just kidding, 13.3 is crazy good for NA!
Old 07-20-2017, 09:25 PM
typeR's Avatar
My car and times are well know. On this board
this is typeR
Old 07-20-2017, 09:47 PM
Received 1,736 Likes on 1,392 Posts
Originally Posted by Karanx7
Welcome to AZine.
Karanx7, you crack me up! He's OG, yo!
https://acurazine.com/forums/members/typer-9212/
Old 07-21-2017, 12:40 AM
Unregistered Member
Karanx7's Avatar
Oh shit it's the real typeR!
Old 07-21-2017, 04:48 AM
typeR's Avatar
I messaged chief F1 asking him to help me figure out my account ... long and short don't have access to my old email so can do a reset pass word
Old 07-21-2017, 08:00 AM
3.5 psi
gnuts's Avatar
Welcome back! What are you driving these days? Did you have a lot of weight reduction with the 13.3 pass? What tires were you running?
Old 07-23-2017, 06:52 PM
mattcl-s's Avatar
Got the manifold polished up the best i could today took a few hours but have not had a chance to tale for a spin yet since i painted the valve covers, plenums and top plate
Old 07-24-2017, 08:31 AM
mattcl-s's Avatar
I just did this over the weekend. I used VHT wrinkle plus to give it a nice texture and also with the valve covers I used VHT wrinkle plus turned out really good
Old 07-24-2017, 08:38 AM
Received 8,584 Likes on 6,630 Posts
@Ron A would be more helpful me thinks
