how tight is to tight?
9.5 lbs o' Boost!!!!
After having the S/C for only about 2 weeks. I am realizing that my boost is going down through sec gear. more specifically @ 2nd gear, WOT from 4k RPM and up. first gear not as much and in third all the boost is there. Yes I do know that the belt must be tightend but how tight is to tight? I have already adjusted it a few times and still the boost goes away in 2nd gear 4k and up. ill gun it and the boost will read about 6 LBS but then the boost will gradually go down to about 2lbs or so, until it hits third gear. In third gear however the boost stays pinned @ about 5-6 lbs. to me it sound like the belt is still to loose. Before I tighten it again I just want to know if I can damage anything by tightening it and Also if anyone can give me a tip on how tight to tension the belt. Thank you all.
As per Shad at CompTech...
Twist the belt to test for tightness between you fingers. Any more than a 90 degree twist is too loose, any less than a 45 degree twist is too tight.
well I tightend it much more then I was doing and all the boost came back. but then shortly after it started to slip away again. I probably just need to tighten it a lot more then I thought.
Originally Posted by mrsteve
DO NOT OVER TIGHTEN!
The belt shouldn't feel any tighter than your other two belts.
