how tight is to tight?
Old Feb 24, 2005 | 01:16 PM
italiaCLs's Avatar
9.5 lbs o' Boost!!!!
After having the S/C for only about 2 weeks. I am realizing that my boost is going down through sec gear. more specifically @ 2nd gear, WOT from 4k RPM and up. first gear not as much and in third all the boost is there. Yes I do know that the belt must be tightend but how tight is to tight? I have already adjusted it a few times and still the boost goes away in 2nd gear 4k and up. ill gun it and the boost will read about 6 LBS but then the boost will gradually go down to about 2lbs or so, until it hits third gear. In third gear however the boost stays pinned @ about 5-6 lbs. to me it sound like the belt is still to loose. Before I tighten it again I just want to know if I can damage anything by tightening it and Also if anyone can give me a tip on how tight to tension the belt. Thank you all.
Old Feb 24, 2005 | 01:44 PM
NSX-Tuner's Avatar
boosted is best
As per Shad at CompTech...
Twist the belt to test for tightness between you fingers. Any more than a 90 degree twist is too loose, any less than a 45 degree twist is too tight.
Old Feb 24, 2005 | 01:46 PM
Smitty's Avatar
24 ft/lbs
Old Feb 24, 2005 | 01:47 PM
Smitty's Avatar
and your problem is common.... everyone who put on a S/C should retighten the belt after 300 miles.
Old Feb 24, 2005 | 02:35 PM
italiaCLs's Avatar
wow. thanks a lot guys. great advice as well as a peace of mind.
Old Feb 24, 2005 | 03:15 PM
italiaCLs's Avatar
well I tightend it much more then I was doing and all the boost came back. but then shortly after it started to slip away again. I probably just need to tighten it a lot more then I thought.
Old Feb 24, 2005 | 05:33 PM
mrsteve's Avatar
DO NOT OVER TIGHTEN!
Old Feb 24, 2005 | 05:34 PM
Cruz_msl's Avatar
My Member is Registered
sounds like rubber bands for belts
Old Feb 24, 2005 | 05:39 PM
italiaCLs's Avatar
alrady happend to me. But in my case is was the bearing that seazed in the tension pulley. I had a alluminum tension pulley made and its working out ok. first of its kind im sure. so now ill know that that particular pulley will not melt anymore.
Old Feb 24, 2005 | 05:41 PM
mrsteve's Avatar
The belt shouldn't feel any tighter than your other two belts.
Old Feb 24, 2005 | 06:23 PM
italiaCLs's Avatar
Ok. Gotchya. I was thinking that but wasn't sure. So as long as the belt is about as tight as the other belt on the HBP then I should be alright. That is a great way to gauge it. Thanks MrSteve.
Old Feb 24, 2005 | 08:50 PM
Smitty's Avatar
I told you that last week......
Old Feb 24, 2005 | 08:56 PM
mrsteve's Avatar
Just spreading the Good News.
Old Feb 25, 2005 | 12:01 AM
darrinb's Avatar
///M POWER
how often do u guys tighten em up??
Old Feb 25, 2005 | 05:37 AM
mrsteve's Avatar
I haven't touched mine since the last time it was installed.
Old Feb 25, 2005 | 05:49 AM
NSX-Tuner's Avatar
boosted is best
I haven't had to re-tighten mine for over 23k miles. I just check it's tightness every other fuel stop. I also check the belt for wear on the grooves.
Old Feb 25, 2005 | 05:51 AM
mrsteve's Avatar
I'm running a slightly larger belt so it took us a while to get it dialed in to the correct tension, I think we've got it this time though.
Pham Alvan
May 18, 2021 06:48 AM
MilanoRedDashR
Oct 2, 2015 10:49 AM
Skirmich
Oct 1, 2015 12:59 PM
polish_pat
Sep 30, 2015 12:22 PM
DementiaPhuro
Sep 29, 2015 05:31 PM
