Emanage users/ amatuer tuners chime in
Old 09-21-2009, 01:51 PM
I got the Shifts
phee's Avatar
just bought an emanage after searching the forum and seeing that the NEO gets over-ridden by our ECU.
So for those of you with emanage, what has your experience been like?
i know some features dont work such as timing right? what else doesnt work?
dd u buy the CD for the unit?
did u tinker with it yourself or get it tuned by someone?
Old 09-21-2009, 02:41 PM
Unregistered user
LIPPSTUH's Avatar
i would get it tuned at a good shop, its worth it IMO
Old 09-21-2009, 05:49 PM
wham bam thank you ma'am
Rajca's Avatar
i believe it reads timing. put it on and limp it to a shop or put it on in front of the shop so u dont have to drive it a distance. let a pro do his magic.
Old 09-21-2009, 06:18 PM
13.2 @ 104.76mph
bigguyonbike's Avatar
took mine to a shop
Old 09-21-2009, 06:31 PM
Whats up with RDX owners?
civicdrivr's Avatar
Received 8,166 Likes on 4,820 Posts
x4 on letting a pro tune with it.
But in my experience, alot of tuners dont like tuning with the E-manage.
Old 09-21-2009, 07:18 PM
Rajca's Avatar
explain what would be better for our cars
Old 09-21-2009, 08:00 PM
civicdrivr's Avatar
For our cars? AEM EMS. It may not be plug and play, but it works.
Most of the tuners Ive talked to all say the same thing; the e-manage is garbage.
Theres no denying the fact that most boosted CLs are using the e-manage though, with success. Its just not ideal, at least from the side of the tuner world that I come from.
Old 09-21-2009, 10:33 PM
Rajca's Avatar
seems like the e mag works for our cars. not sure about the ems bc we havent had an update from that one member that was running the mp90 or92 supercharger. o well.
Old 09-21-2009, 11:20 PM
civicdrivr's Avatar
He wasnt running the EMS. JPRoy was running the FIC I believe, but theres another guy on the other site running it on an NA motor with no issues.
The EMS is a full standalone. It will work. Its expensive, and requires you to wire it up. Theres no OEM ECU to override it.
Old 09-22-2009, 04:34 PM
I got the Shifts
phee's Avatar
aem ems isnt an option. ive seen plenty of good things with emanage. and i really only need A/F.
Old 09-22-2009, 05:27 PM
Rajca's Avatar
why not?
Old 09-22-2009, 05:43 PM
I got the Shifts
phee's Avatar
price. plus i already bought an emanage
Old 09-22-2009, 07:45 PM
civicdrivr's Avatar
Good reason
The EMS is pricey, but definately worth it.
Old 09-22-2009, 10:58 PM
MP90 uninstalled
jproy's Avatar
Im not done yet. I will get back on it and finish it in a week or two. Been very busy.
Old 09-22-2009, 11:31 PM
I got the Shifts
phee's Avatar
ahh. looking forward to see whats up. so did we ever figure out what your using?
emanage?
or EMs?
Old 09-23-2009, 07:19 AM
lowrd on tein CS biatch
CL-S progression 01's Avatar
If I want to tune my set up i got now. what should I USE.
Since I know NOTHING about this piggy back systems you are talking about.
AEM EMS is that a full standalone? I could run that right?
Old 09-23-2009, 08:25 AM
Rajca's Avatar
U should be good with and e man
Old 09-23-2009, 12:39 PM
civicdrivr's Avatar
emanage?
or EMs?
Last I checked JP is still using the AEM FIC.
The EMS is overkill for you. If anything, you just need a bump in fuel, so the E-manage would work.
Old 10-13-2009, 04:55 AM
Never had a clean run
rtatsutani's Avatar
Brought my 3.5L to a shop with emanage blue and they could not get anything out of it. They said the ECU kept overriding it and caused my car to run worse. I eventually took it off. If anyone else has any success stories with any other piggy back unit, let me know b/c I am dying for a custom tune.
Old 10-13-2009, 05:25 AM
Turbo 6 Speed
CL-S6's Avatar
Thats strange. I was running e-manage on my boosted cl-s with no problems. You sure your tuner knew what he was doing? Alot of the members here used it with no issues.
Old 10-13-2009, 09:16 AM
CLsuperhero's Avatar
mega squirt?
I would stick with e-manage since you only need A/F. It may not be the best thing, but it seems like the most inexpensive solution. Our Ecus are a pain and there is always a probability of getting over ridden with a piggyback.
Old 10-13-2009, 10:20 AM
I got the Shifts
phee's Avatar
no one has reported the stock ECU overriding and emanage. only problems ive seen are with the neo.
if ur stock ecu over rides the eman i would suggest looking over the wiring and maybe using an 02 clamp
Old 10-13-2009, 10:25 AM
I got the Shifts
phee's Avatar
Old 10-13-2009, 12:11 PM
Rajca's Avatar
That, or the shop doesn't know what their doing
Old 10-13-2009, 01:01 PM
I got the Shifts
phee's Avatar
im leaning toward what matt said
Old 11-24-2009, 05:01 AM
rtatsutani's Avatar
Couldn't be the wiring, I ordered the boomslang. Well, they tried and tried and only squeazed about 5 HP out of it. But the real issue was that I'd have to pull the battery every 50 miles or so b/c the CEL would turn on and my car would begin running like crap. Anyways, it's too late now, i already sold the emanage lol.
Old 11-24-2009, 08:41 AM
I got the Shifts
phee's Avatar
^ doesnt sound right. you sure your 02 sensor was working? did u use a WB?
Old 11-24-2009, 11:53 AM
civicdrivr's Avatar
Yea, doesnt sound right at all.
Old 11-27-2009, 10:54 PM
Rejckt's Avatar
What does the AFR look like when the ECU is overriding the Emanage? I've started on the airflow chart and no matter what values I put, my wideband fluctuates from 11 to 21.
Old 11-28-2009, 08:24 AM
Turbo 6 Speed
CL-S6's Avatar
Are you getting on and off the gas when the afr changes like that?
Old 11-28-2009, 09:01 AM
Rejckt's Avatar
No, that's the IDLE lol...
Old 11-28-2009, 11:39 AM
civicdrivr's Avatar
Test your o2 sensor.
Pull it out, spray a rag with carb cleaner, and cover the end with the wet rag while the sensor is cold. Keep an eye on the gauge, as the sensor heats up the gauge should slowly go 100% rich. If it fluctuates, then your sensor is bad.
Old 11-28-2009, 12:26 PM
Rejckt's Avatar
o2 sensor is brand new.
Old 11-29-2009, 03:44 AM
civicdrivr's Avatar
Doesnt matter.
Old 11-29-2009, 09:28 AM
Rejckt's Avatar
which o2 sensor should I test? The gauge, or bank 1
Old 11-29-2009, 10:57 AM
Rejckt's Avatar
I don't think its the o2 sensor, I'm having the same problem as this guy https://acurazine.com/forums/2g-cl-2001-2003-50/help-440cc-rc-injectors-emanage-woes-487861/
Old 11-29-2009, 12:41 PM
civicdrivr's Avatar
The wideband sensor hooked to the gauge.
Old 12-03-2009, 08:43 PM
Rejckt's Avatar
problem was afr calibration =/ ez fix. emanage is quite ez to use.
Old 09-23-2010, 01:31 PM
3.5 psi
gnuts's Avatar
sorry to bump this but got a quick question. Someone local is selling an Emanage. They had it on a 6th gen accord v6. This will work right? The unit is the same and it's just the harness that changes from car to car right?
Old 09-23-2010, 03:01 PM
2003 CL-S 6MT
Total2f's Avatar
Yes, as long as its a Emanage Blue; the unit itself is universal just the harness changes like you said. So you'll just need to borrow/buy the support tool, get a Boomslang PnP harness, and install a wide-band air fuel gauge.
Quick Reply: Emanage users/ amatuer tuners chime in
