View Poll Results: Performance Radius Rod Bushings Poll
Yes, I'd be all over this
60.00%
Maybe, depends on costs
40.00%
No, not interested
0%
Voters: 10. You may not vote on this poll
Aftermarket Radius Rod Bushings Poll
Lead Footed
It's been about 1 1/2 years since we've visited the topic of having some performance radius rod bushings made for 2nd Gen TLs.
If you are interested in this mod please respond accordingly.
1) Yes, I'd be all over this
2) Maybe, depends on costs
3) No, not interested
Ruf
Ruf
CLSspeedx (08-05-2011)
i noticed that i have alot of wheel movement when i let my brother drive my car while he was leting clutch of the wheel started to move alot back and forth im not sure if that can be caused by mounts or only radious rod bushings
sounds like another 2 years of development
I would be interested. I have the moog improved design ones that I havn't installed yet so not sure if they are an improvement. They are alot stiffer than stock ones tho just by feel.
Whats up with RDX owners?
Yesyesyesyesyesyesyesyesyesyesyesyesyesyesyes.....
All it would take is a mold and pouring some polyurethane. Theres nothing to the stock bushings, just a big chunk of rubber.
Moog makes radius rod bushings?
Interesting. I saw those on their site but their name for them threw me off. The Accord shares the same part, so the should fit. Good thing, Ive got a set of ES (I think) bushings off an Accord sitting in my garage
BTW, has anyone actually ever replaced the radius rod bushings on the CL-S?
The manual states the following:
1. Raise the front of the vehicle, and make sure it is securely supported. Remove the front wheels.
2. Remove the clips and splash guard.
3. Remove the flange bolts to disconnect the radius rod from the LCA.
4. Remove the self-locking nut, washer, and front side bushing.
5. Remove the radius rod, collar, rear side bushing, washer, and shim.
6. Install new bushings in the reverse order of removal, and note the following items:
-Use a new self-locking nut on reassembly.
-Note the direction of installation for the front side bushing and the rear side bushing.
The reason I ask is because those flange bolts are a MFer to work with since space is tight in that area due to the axle. Making socket/wrench positioning difficult for removal/reinstall and final torque to 119lbf-ft.
I guess one could pop the lower ball joint for more flexability, however.
The tapered end of the larger one points to the front of the car and the tapered end of the small one points toward the rear, two for each side.
If your caster angle is out of normal limits the manual states to:
'Adjust the caster angle by increasing/decreasing the adjustment shims.
Note these items during adjustment:
-Do not use more than two adjusting shims.
-One adjusting shim changes the caster angle by 35` and the caster angle can be adjusted by 1 degree 10` maximum.
-One adjusting shim is 3.2mm (0.13in.) in thickness.'
Those flange bolts are a royal pain in the ass to remove. When I replace the RR bushings, Im going to replace my lower control arms too since those bushings have 140k on them, and hopefully it will make it easier to remove those bolts. I will be doing that probably within the next month or two.
The ES part number is 16.7103 but they are just the bushings, they dont include the sleeve or any washers. They were ~$20 for the set.
I got them here:
http://www.energysuspensionparts.com...prod=16%2E7103
Theyre pretty good, I ordered a few things from them.
I got them here:
I got them here:
I got them here:
In addition, ES has the Moog kit #K9733 on thier website supporting the 02 Accord Coupe as well for $35.94. I was going to get those but decided to opt for the ES since I was not at all impressed with Moog's inner/outer LCA bushings when I tried them.
CLSspeedx (08-02-2011)
You would have to start at the '96 master kit first since that is the last year for the radius rod set-up on the Prelude. The ES 16.7103 is applicable to that model year (96).
Thats only the SH model that uses the horizontal bushing setup. The base model still used the conventional radius rod setup.
Lead Footed
Just checked . . . the 98 Prelude and 2nd Gen CL/TL have the same part number . . .
Ruf
51381-SX0-013 011 002 BUSH, FR. RADIUS ROD (RR) (HOKUSHIN)
51391-SX0-013 012 002 BUSH, FR. RADIUS ROD (FR) (HOKUSHIN)
03 TL/CL:
51381-S84-A01 BUSH, FR. RADIUS ROD (RR)
51391-S84-A01 BUSH, RADIUS ROD (FR)
They share the first five digits; however, they appear to differ slightly in the parts diagrams.
After awhile, to me anyways, it seems like those numbers all blur together similarly.
I'm down for this!!
My car did same thing before. My buddy told me that i have wheel movement back and forth. so i removed radius rod for checking. sure enough my bushings were bad. I replaced w/moog bushing kit. and kit doesn't come with locking nuts. I had to buy 2 new self-locking nuts. after that we checked if there's still movement. There wasn't movement. That's like 1.5year ago. maybe 2. I think it's time to check again.
zeta (08-01-2011)
Lead Footed
Now that we know the bushings are the same for the CL/TL as certain model year Accords and Preludes maybe we'll find some more options.
Here's one that I found. It would be good to know how the Moog and these match up.
http://www.redlinemotive.com/store/r...tion=000783109
Ruf
Ruf
Lead Footed
Okay, I just caught this the Moog K9733 are strut mount bushings, but you guys say they are the same spec as the radius rod bushings?
Just want to make sure because if they are not the exactly the same I'm not going to mess with them.
Ruf
Ruf
MOOG calls the radius rod bushings the strut rod bushings. Its misleading.
For instance, Moog #K9492 is in regards to the upper front suspension 'strut mount kit' meaning 'shock/strut' mount rubber. see link below.
http://www.rockauto.com/catalog/moreinfo.php?pk=225530
Lead Footed
From what I can find on RockAuto and per brian6speed above, the Moog K9733 kit is for CL/TL 'radius rod' use. The confusion pertains to the symantics of the description, meaning 'strut rod' bushing kit.
Ruf
Senior Airman
They also have Prothane bushings available and are a little bit cheaper: http://www.energysuspensionparts.com...asp?prod=81202
Which are better Energy Bushings or Prothane?
'03 ABP YA4-S 6MT
http://www.amazon.com/Moog-K9733-Bus.../dp/B000C5A1HK
$29.84 including shipping from amazon
http://www.amazon.com/Energy-Suspens.../dp/B000CNAVL8
$21.03 (cheaper than other sites but need cart to be over $25 for free amazon shipping)
i think i'm going with the energy ones though.. and just reuse the collar and washers
If the picture on ES' website had something next to them to show their scale, it would be apparent that these are in fact the correct size for radius rod applications.
In addition, holding these in my hands and comparing them to brian6speeds pictures above, the Moogs do, IMHO, appear to be the same size. I can barely get the 16.7103's to bend when trying to squeeze on them like in the photo above. I'm impressed and will try and get them installed ASAP.
CLSspeedx (08-04-2011)
Good to know thanks zeta! I'm going to work on my suspension after I get my car from the transmission shop. I'm planning on getting new radius rods and think I'll change out the bushings... Good luck getting them installed!
lol, refer to post #9. Those steps are straight from the manual. As mentioned in that post, step 3; removal of the flange bolts to disconnect the radius rod from the LCA will pose as the largest hurdle. If you are not familiar with this area by prior work exposure, it would be best to let a local shop perform the job. Depending on the types of tools available to the individual, it could be real easy or labor intensive because access to those bolts for wrenching is very tight.
Lead Footed
Ruf
I installed these ES radius rod bushings today and it went very smooth. Took the car for a quick spin and it felt tighter/firmer. I did'nt go to crazy because the next step is to get an alignment to see if the caster is in the green. Logically, everything SHOULD be within normal limits with just the new bushing install; however, I have learned that my front suspension can be finicky when I go and mess with it.
The old stock bushings were SOFT, just like in brian6speeds photos above. They were not cracked/split or deteriorated, just contorted from being compressed/used for the last 125K or so. 80K of those 120K have been with the added weight of a S/C'er, so that has to be factored into the overall effect on the whole suspension geometry as well. They needed to be replaced.
I added to step #3 to indicate what I had to do to get the RR arm off the LCA, YMMV.
a. Detach the outer tie rod end.
b. Detach the endlink from the swaybar.
c. Detach the strut damper fork from the strut and LCA and set it aside.
d. Detach the lower balljoint, I used the socket handle between the LCA & Knuckle method.
e. Swing the knuckle assembly, supported by a jack, forward slightly. This will move the axle forward and away from the LCA area where the RR flange bolts reside.
f. I used a 19mm impact socket on a long 1/2" breaker bar while slightly pushing down on the LCA to loosen them. Once they are removed from the LCA, follow the remaining steps below.
4. Remove the self-locking nut (I replaced mine, torque to 40 lbf-ft), washer, and front side bushing.
When all suspension components have been reassembled, be sure to preload the suspension before torqueing all of their related fasteners.
Good Luck!
Good Luck!
The following 2 users liked this post by zeta:
Neejay (11-09-2011),
ProfessorFunk (12-26-2018)
