AEM EMS Speedo and RPM fix
Old Jan 18, 2013 | 02:04 AM
JohnsonCG's Avatar
AEM EMS2 6051
Speedo Fix:
First:
Second:
Unplug the upper plug and let it chill
Unplug the lower plug and plug it into the upper sensor
If you have a 1998-2002 accord v6 this rpm fix is for you:
For the rpm fix the ems is designed for civics so it is calibrated for the 4cyl cluster. What I did to get the correct reading on the ems was just swap out my v6 accord cluster for a 4cyl accord cluster.
Important tip:
NEVER MESS WITH THE AUTO TRANSMISSION RANGE SWITCH when the ems is plugged in. It fries a resistor in the ems. This means you cant wire up the reverse lights to the range switch. When you plug in the ems the reverse lights will always be on. The only solution is to just disconnect the plug for the bulbs.
Hope this helps everybody. Thanks for reading and have fun!
Old Jan 18, 2013 | 02:42 PM
brian6speed's Avatar
Lone Wolf
What swap do you have? Auto j32 with manual tranny in 6th gen accord?
I doubt anyone with a 2nd gen cl is running the ems. I have yet to see it.
A DIY on how to get it to work on the manual motor would be of great help.
You should post on j swap forums if you havnt already.
Old Jan 18, 2013 | 04:59 PM
rush's Avatar
03 acura cl type s
^ Yea he said but thanks keep us updated
Old Jan 18, 2013 | 06:40 PM
fsttyms1's Avatar
People looking for a tuning solution really should be running it. Its the only way as of now to do so. How to get it to work on the manual motor, thats easy. Swap the engine harness to the Auto harness, Get the Crank position sensor and gear from the auto and get the front cam and 2 ckp sensors.
Old Jan 18, 2013 | 08:18 PM
JohnsonCG's Avatar
I have an auto j32 with a manual tranny in a 6th gen accord. fsttyms1 is correct. The ems is made only for an auto motor with a manual transmission. So you have to convert the manual motor to an auto motor by swapping the stuff he said
Old Jan 18, 2013 | 08:59 PM
Lone Wolf
I think civic mentioned to me that him and Paul were working on a solution that wouldn't require you to do all that. I think he said something about modifying the internals of the ems but they might have given up since he dsnt care about cl anymore.
But what do I know.
Old Jan 20, 2013 | 12:18 PM
civicdrivr's Avatar
But what do I know.
Correct, and not much modding what so ever. Simply take the two boards of the EMS out of the shell, carefully separate them, and move the jumper over. Its clearly labelled MAG and HALL for the sensor set. No need to swap any engine harnesses. This will void the AEM warranty though.
You will however need a jumper harness for the ECU plugs. Which is no biggie. RPM read steady on the CL-S6 gauge cluster too. The exhaust is quiet, but look at the computer towards the end, its running.
Video, might open in a pop up:
AEM does not mention anything about the jumper, as they technically dont support running the 6MT harness, nor do they want to. They have the system setup for the auto crank gear reading, and dont want to incorporate the 6MT. So in that video, the car is reading off of the bellhousing mounted crank sensor. The a/c kicks the IACV on just as stock too, using one of the EMS' inputs to read when the clutch kicks on. The only thing that doesnt currently work is the temp gauge, because the temp sensor on the motor sends the reading through the ECU then to the cluster. Haven't looked into it, nor do we plan on it since Im moving onto an Accord (which sends the temp sensor reading directly to the gauges).
Old Jan 20, 2013 | 12:42 PM
Lone Wolf
That sounds promising. I was going to use an aftermarket temp gauge anyway. What jumper harness would you need?
So you are still planning an accord sedan build? I thought you had given up.
Old Jan 20, 2013 | 01:51 PM
civicdrivr's Avatar
The jumper is a one-off.
Nope, still getting out of the CL. I entertained another project but its not logical for a daily, though it would be insanely unique and pretty damn fast.
Old Jan 20, 2013 | 02:21 PM
rush's Avatar
03 acura cl type s
This will be my final mod. I keep lying to myself lol
Old Jan 20, 2013 | 03:08 PM
jaeravenal's Avatar
Membistered Regember
Windows XP based god
Old Jan 31, 2013 | 07:20 AM
rush's Avatar
03 acura cl type s
This IMO would be the best & cheapest for those converting to manual
Old Jan 31, 2013 | 08:49 AM
fsttyms1's Avatar
This to me is a problem as it limits you to use the CL-S6 trans and clutch. For those looking to do the swap, and wanting to use the TL 6 trans, or a cl-s6 wanting to use a different flywheel you cant as it doesnt have/read off the flywheel sensor.
Old Jan 31, 2013 | 11:45 PM
civicdrivr's Avatar
Correct me if Im wrong with my line of thinking, but for those using a TL6 tranny or a non CLS-6 flywheel would typically be running the auto harness and sensor set, so the method posted above doesnt apply. BUT - We did send a 6MT crank gear in to AEM for them to measure and incorporate into the software. That was over a year ago though, so the likelihood of anything coming of it is slim. Its my understanding that its just a config change though.
Old Feb 1, 2013 | 09:02 AM
fsttyms1's Avatar
Not necessarily, If you already own a CL-s6 and would like to be able to use the aem would probably like to not have to be stuck with the limited flywheels available out there. It would just be more convenient if the software was able to be used with both auto and manual
Jul 16, 2017 07:33 AM
DerrickW
Nov 15, 2015 05:52 PM
lanechanger
Oct 13, 2015 10:56 AM
rangomango
California
Sep 24, 2015 05:47 PM
