2001 cl type s overheating while drive not while idling
Ok I changed thermostat changed radiator n now the car overheats after half hour of driving i flushed the radiator as well. Um now it leaks from the thermostat housing I dnt knw if waterpuMp is out or what please help me
milage on car?
overheat while driving might indicate some other issues
you need to remove thermostat and make sure it is installed correctly and that you have properly tightened it
lowrd on tein CS biatch
first plz mention why u did the rad and thermostat change in the first place... was there a problem u needed to fix?
are u 100% positive u put it in the right way and not backwards??? this happens more often than u think.
if it is stuck closed u will only have the upper rad line get hot and the lower rad line will stay MUCH cooler in comparison.
2 are u sure u put the rad lines back in the same order?
u may have crossed the lines at the thermostat and that would overheat the car too i believe.
my money is on you put something in the wrong spot.. happens to us all.... eventually
