03 CL-s swap 93 civic AEM speedo.
To start off my setup.
I have a 1993 civic with a full manual 03 CL Type s swap in it. I am running a stock built CJs wiring harness to use stock ecu. Everything worked great no issues. I switched over to AEM 6051 with the Boomslang jumper harness. Everything currently works other than the speedometer. I'm no showing any Vehicle speed in the AEM tuner or on the dash. any help is greatly appreciated. https://cimg2.ibsrv.net/gimg/acurazi...4a79aa3cf9.jpg |
I'm not really worried about my cluster I'm just trying to get it to show VSS in the software. I'm not getting any feedback.
I currently have these pins plugged AEM. Engine side D9. SG3 sensor ground D11. Mainshaft speed sensor D10. Countershaft speed sensor D12. Has nothing in it. |
PFI speed on youtube showed how to get around this issue, I think...lemme find it for you
(Post 16396300)
they never really specify where the D9 pin goes on the engine and so forth. I've tried everything but still no VSS on the Software. Aem isnt seein any of it |
comment on the video!!!!! Brent is awesome and loves to help out
I have been emailing Jamie and they haven't gotten back to me yet. But hopefully they can help.
Originally Posted by Civiceg_type_s_
(Post 16396285)
I currently have these pins plugged AEM. Engine side D9. SG3 sensor ground D11. Mainshaft speed sensor D10. Countershaft speed sensor D12. Has nothing in it. I'm looking at the Boomslang AEM 6051 2001-2003 Acura CL Manual Transmission schematic (pinout; or whatever it's called :) ) they (Boomslang) provide when one purchases their harness to connect the AEM 6051 to the CLS6 wiring harness. This is what it states for the items you have listed above: 6051; Function; CL D9 SG3 E7 D11 Mainshaft Speed B16 D10 - D12 Clutch Switch E17 For the Counter shaft Speed it has 6051; Function; CL C29 Countershaft speed B7 I can't see anything that specifically says 'speedometer'; however, it may be here labeled as some other 'function'. :dunno: |
(Post 16396308)
I've watched that video a million times already... haha
they never really specify where the D9 pin goes on the engine and so forth. I've tried everything but still no VSS on the Software. Aem isnt seein any of it 6051; Function; CL A9 VSS Out E26 Maybe that's your Speedo?? :dunno: |
Originally Posted by zeta
(Post 16396331)
I'm not sure if any of this will help you; so I'm just throwing it out there for you to consider. :shrug:
Originally Posted by 2ndgentl
(Post 16387898)
https://cimg1.ibsrv.net/gimg/acurazi...ce8ba3b27f.jpg
https://cimg1.ibsrv.net/gimg/acurazi...2df509863b.jpg https://cimg8.ibsrv.net/gimg/acurazi...e856b8da19.jpg https://cimg5.ibsrv.net/gimg/acurazi...74bda598a8.jpg https://cimg6.ibsrv.net/gimg/acurazi...330e1427f6.jpg |
(Post 16396348)
I don't have a file or working scanner, just a hard copy, at the moment; however, the guy above just received his and he left pictures. Maybe it will help?
currently I have D10 going to B7 and nothing in C29. Hopefully I swap that and she works. |
(Post 16396348)
I found a few other things wrong compared to the diagram. C8 going to A11(should be A12)according to diagram... C20 going to E11(should be A11) C29 has nothing. (Should be B7) |
https://acurazine.com/forums/second-...pm-fix-878358/
That should clear up the problem for the speedo. Essentially, the AEM should provide sensor ground to D12, but it doesn't do that for whatever reason. D9 is a close by sensor ground, so you can splice into that. This will provide D12 with sensor ground and allow the speed sensor to work. |
