Long cranking before it starts, also chirping noise from engine
Anyone know what could be causing my issues? I was planning on taking it to the dealer to get their opinion but would like to go in with as much information as possible so I wanted to ask here first.
I have a 2010 TL SH-AWD 5AT with about 110,000 kms.
Car was perfect until about a week ago. Now when I go to start it, it'll crank for about 5 seconds before it starts. If I turn the key to on and hold it in on for a few secs to let the fuel pump do its thing and then try to start it, it will only crank for about 2 secs before it starts. However until a week ago I didn't have to do this, I was able to start it right away each time with almost no cranking even on the coldest days.
Also about a week ago, the engine started making this sound while idling, almost like a bird chirping. I do not know whether the two issues are related but it's suspicious that they both appeared at the same time.
Other notes:
-The car has never given me a single problem before in the 3 years I've owned it
-The car is completely stock
-The car has never had any work done on it in the 3 years I've owned it, other than basic maintenance like oil changes and air filter change
-There is no noticeable difference in the way the car drives, it's just the chirping sound and the difficult starting
Any ideas what it might be?
Other notes:
Dejan, chirping is usually a problem with an idler or tensioner Pulley. While it is chirping, spray some CRC or PB Blaster on the belt. See if the noise goes away. Another thing you can do is detention the belt and pull it out of the way of the crank fully and see it this quiets it down. You can't drive the car like this (no power steering and you alternator light will be on) but you can run it for a few minutes to see if this quiets it down. If it does, stop the engine and spin the alternator and tensioner pulleys and see if they are making racket or don't spin freely.
As for the long start, could be fuel quality. Could you have some water in your gas?
Other notes:
Other notes:
Ok so chances are of this car having a bad starter are pretty slim. However I have seen some fuel pumps prematurely fail on these cars. If you can get a friend to bang on the fuel tank while you start the car. If it fixes the problem you probably need a new fuel pump. Otherwise we will need to start getting into fuel delivery and ignition.
Long cranking can be due to a faulty fuel pump, bad coils, bad plugs, faulty crank sensor, bad injectors etc.
His issue will either be a fuel pump or crank sensor is going bad.
To ignite the engine you need a mixture of fuel, spark and air. So if he has fuel and car is not starting and still cranks it could be anything.
Do your homework kid.
Other notes:
Other notes:
Thanks for all the suggestions guys but the problems disappeared on their own. I'm pretty confused. I took a long road trip a week ago and when I came back both problems were gone. Car starts up without cranking, and no funny noises from engine. Only thing I can think of is that the car had old/bad gas in it. Prior to my road trip I hadn't filled up the tank since February because I'd been working from home and also my girlfriend drives me everywhere, so my car barely moved.
