Torque Spec for Shock Assembly 3G Garage #D-091
Old Feb 1, 2008 | 06:56 AM
Bearcat94's Avatar
AZ Community Team
Anybody have a Service Manual that can post the Torque Spec for the nut(s) that hold the Front and Rear Shock Assemblies together?
Replacing springs tomorrow (H&R Sports) and we have scans and Torque Specs for the Seats and for the Suspension Connections to the car (Strut Tower, End Links, Thru Bolt, Pinch Bolt, etc).
What I don't have are Specs and/or Scans for the the nut(s) that hold the Spring in place to the Damper itself. In the attached parts drawings, I think these are items 19 (Rear) and 17 (Front).
Rear Assy:
Front Assy:
TIA.
Old Feb 1, 2008 | 11:33 AM
Ron A's Avatar
Administrator
You only asked for the torque specs, but I scanned all the pages for the front and rear shock/damper replacement so they would all be in one place.
Old Feb 1, 2008 | 11:12 PM
mmade22's Avatar
200,000 mile club
Thank you Ron!
Old Feb 4, 2008 | 03:35 PM
Bearcat94's Avatar
AZ Community Team
Ron A, you are my hero.
Used this post throughout the day. All parts torqued to spec. Thanks again.
Old Nov 17, 2008 | 04:05 AM
eganchor's Avatar
I'm new to this post. It's awesome. Thanks Ron, UR the best.
Old Aug 3, 2011 | 02:53 PM
4 bangin's Avatar
thanks ron ill be doing this on sat
Old Apr 2, 2012 | 08:02 PM
easygoingtl's Avatar
I was naively thinking I could change the shock aborbers myself to save a little cash on my 04 TL, but after looking through the instructions I overestimated my abilities. Hope the Acura dealership I ordered them from will take them back. I owe you a thanks as well Ron.
Old Apr 2, 2012 | 10:33 PM
Ron A's Avatar
Administrator
Welcome to the forums.
It's always nice to see an appreciation for my work. Thank you.
Old Aug 18, 2012 | 08:11 PM
VanGuy's Avatar
Notes for anyone attempting this. I bought the entire front strut assembly so it was fairly easy for me to install. However, I did run into some difficulties trying to insert the bottom pin labeled 'E' on page 18-28 of the print out above. The secret is to use a crow bar & leverage the wheel/rotor at the back of the wheel against the sway bar lower mount bolt. Push down hard or have an assistant do it. I highly recommend having an assistant handy. This will force the bolt holes on the damper fork/wishbone (labeled 'A' on page 18-23) to realign momentarily so that you can reinsert the pin back through the damper fork. If aligned correctly, you can push the pin back in with two fingers. If you're hammering it back in then something is wrong. Also, don't try to get smart & reinsert the pin from the back/rear of the vehicle. It doesn't work that way! Always reinsert the pin in from the front! It was a joke to re install once I figure that out. I hope I helped someone with this info.
Old Jun 15, 2013 | 10:06 AM
TegoTL's Avatar
Is it necessary to have air tools for this or by hand should be fine? My car's only 5 years old. .
Old Jun 15, 2013 | 12:19 PM
Sinistr's Avatar
I'm going to be installing the ASpec suspension soon and having these torque specs will make me feel better on this install. Thanks!
Old Jul 3, 2013 | 11:46 PM
VanGuy's Avatar
Hand tools are fine if you ordered the entire assembly like I did. There is no need for air tools but you should definitely have an assistant on hand. You MUST push the rotor down to realign everything to slide the bolt back through. I suggest having your assistant stand on the rotor with a crowbar safely lodged in the rotor somewhere. Be careful though. Just remember that and everything else is quite easy.
Note: If the holes are aligned then you can use just finger pressure to slide the bolt back through.
Old Feb 14, 2026 | 01:59 PM
AceWright's Avatar
5th Gear
Smile
It seems these photos are not available anymore. I need the torque values for 2013 Acura RDX front and rear, top and bottom bolts. Do you happen to still have them Ron? Thanks
Aug 15, 2019 12:58 PM
ArcticDuk
Jun 29, 2016 06:57 AM
Sep 17, 2015 09:01 PM
proxus
Sep 16, 2015 06:18 PM
