F-179: DIY-Pass. Door Lock Actuator Replacement, W/ Pics
My first ever DIY and I am not computer savy, do not know how to take pics, can't find camera( pics with my cell, sorry for quality) and nervous if i forgot something or not explained well enough. Here it goes.
This is really a pretty easy fix, Mods and others please add or help explain. This is on the Front pass. side 04 TL Base.
Tools needed are #1, #2 and a #3 philips screwdriver, special trim removal tool(do not have to have). Good Tunes!
Leave window up and disconnect battery(if you are that type) and remove door panel. Here is the link to The 3G garage scans for removal and Door Latch Replacement
https://acurazine.com/forums/car-talk-5/my-car-super-street-143797/
It is easy if you can have the door wide open.
Once the panel is off peel back the white plastic from right to left gently and with caution just pass half way of door.
The Actuator is on far right side in center, there are two grey connectors attached and one whitish/gray cable and one black cable.
0217001744_0001.jpg?t=1266461292
Unplug the connectors.
Then look inside the door at the actuator/assembly with a flashlight
0217001741_0001.jpg?t=1266461662
Disconnect the brown clip, it goes towards the inside of car. remove the metal rod from hole and let hang.
Remove the 3 screws on outside edge of door to release latch assembly.
0217001736_0001.jpg?t=1266462098
Pull out assembly carefully, pay attention to the cables and how they are routed and take a good look over the whole assembly and compare with the new actuator in relation to the old one installed.
There is a cover over the assembly that has to come off to get inside and remove screw and clip.
0217001745_0001.jpg?t=1266462417
Remove that screw.
0217001748_0001.jpg?t=1266462469
undo that latch and slide/pull the cover off and along the cables.
0217001749_0001.jpg?t=1266462596
Remove the screw and undo the purple clip ad remove cable.
Also remove the purple clip from old Actuator and install in new actuator.
Make sure the new actuator is installed the sameway it came out.
0217001755_0001.jpg?t=1266462837
0217001754_0001.jpg?t=1266462880
Make sure those are connected/mated correctly once you are ready to install. Read this post in reverse to put back in. Hope this turns out well, I take criticism very well so do not hold back.
Remove that screw.
Wow.. So I'm new to this forum, but I have a 2004 tsx I just recently bought, and the front passenger door lock doesn't work when I press powerlock for all the doors in the car.. well I went to a mechanic and he checked it out and says that I need to order "pass door- door latch mechanism for 2004 acura". Is this the same as the actuator that you are showing here?
Nice DIY, with pics!!!
Nice to have "substance" on this forum to go along with all the fluff!! Very good job and you saved yourself tons of $$$$ by doing it yourself. Also potentially saved many other folks some $$$ too who benefit from your write up.
Thanks!!
Thanks!!
just replaced mine yesterday. not too bad. i did the drivers side door. i think it was about the same. hardest part was getting the 3 screws off that hold the locking mechanism in place. i almost stripped one. but thats another story. everything came apart easily and went back together the same. thanks for the diy, it helped a bunch and saved me some money. Total cost was 23.00 after tax for the part and the whole thing took about an hour.
Thought I could add to this old thread. Guys, try some "valve grinding compound" dab some on your screw driver tips for extra "bite" before removing the said screws that seem to strip out. Sounds hokey, but it actually works very well. You can pick up a small tube from any auto parts store for cheap. Key is to do it BEFORE removing the screws, but it may also bail your but out if there half stripped.
Thanks for the DIY... once I got the door panel off it was pretty straight forward.
I had a hard time locating some of the clips at first, but I found that using my cell phone camera as a live video monitor made the task very easy.
Now, I'm off to order a new "nut" for the stopper screw. What a terrible design for that one little piece
I've recently been having trouble with my locks as well. They unlock fine (with the remote, with the buttons and with the key hole in the door) but will not lock with the remote or from the lock button on either door. If I use the key only the drivers door locks, the rest I must do individually
Does this sound like it is an actuator problem also? Would it only be the driver's side? It doesn't seem possible that both actuators would go at the same time.
This has been going on for a few weeks and is getting to be a pain.
Thanks for any help/suggestions.
I also now have this issue on the driver side front door, need to replace the actuator. However, I can't get the * door panel off! The stopper screw (lower left) turns and turns and refuses to come off the door. I've even attempted needle nose pliers on the other side of the plastic to hold one side still, no dice. Anyone seen this, got an tips so I can get my panel off?
Is there some kind of trick to getting the old actuator out of the door once it is free. I can't get it out of the door no matter what I try. Anyone have any trick to getting it out? I have everything off and the screws renoved b ut I can't wiggle it free.
Thanks.
Thanks.
Bump. I'm having the same problem exactly as well. Need to know if its the actuator in driver's door or if it is something else. Could drop by the dealership and ask them, think they would know just from asking them?
Went by the dealership today and guy said that would be a good place to start and probably a pretty good bet to fix the problem. Let us know if it fixes the problem. I may not be able to tackle it until the summer sometime, but if I get it done before I'll post back.
So, I plugged in code reader today just to make sure there weren't any DTCs. There were not, but when I unplugged the code reader, the door switches and key fob started working again. I don't know how long it will last but I'm glad it working again for now.
Thanks for the update and good info to know. Mine are still working fine (knock on wood) after the trick of plugging in the bus reader that last time. Good for close to a month now, but should I have the problem again, I will plan to replace. Did you do the actuator replacement yourself? How long did it take you? Thanks again.
I need to possibly replace mine but I am having trouble getting the driver door inner latch cable disconnected from the door panel. Is there some sort of trick to disconnect the cable without breaking the green plastic connector?
Mc
I just barely stripped the screw (just enough to where I cant get Phillips head to bite) and stopped before doing serious damage. The mechanism is not being replaced, just the actuator, so I am trying to save that piece.
