Clutch stuck on floor?
Old Jul 7, 2014 | 03:05 PM
ChuckP's Avatar
I went to start my 05 tl today and the clutch became stuck in the lower 1/3 of the travel. I couldn't get it into any gear. So after repeatedly pumping the clutch and turning the car off and on a few times. It finally came back up and now everything works normal again. Is this the clutch salve master? Or something else? I changed the fluid and bled it properly when I was doing my brakes about 6 months ago.
Old Jul 7, 2014 | 04:09 PM
ChuckP's Avatar
Originally Posted by ChuckP
I went to start my 05 tl today and the clutch became stuck in the lower 1/3 of the travel. I couldn't get it into any gear. So after repeatedly pumping the clutch and turning the car off and on a few times. It finally came back up and now everything works normal again. Is this the clutch salve or master? Or something else? I changed the fluid and bled it properly when I was doing my brakes about 6 months ago.
Edit, I am leaning towards the master at this time. Its popping and making a binding noise when depressed. Any way to diagnose which one is the culprit?
Old Jul 7, 2014 | 06:30 PM
Turbonut's Avatar
I say clutch master cylinder, but check system for any leaks.
Old Jul 7, 2014 | 07:55 PM
ChuckP's Avatar
I'll be doing that tonight. Is there always a visible external leak when one of these cylinders fails?
Old Jul 8, 2014 | 06:28 AM
Turbonut's Avatar
No, but check the slave also for any leaks. If they are resonably priced, I usually replace both at the same time.
SidhuSaaB
May 30, 2020 12:40 AM
Jul 16, 2017 07:33 AM
knight rider
Mar 4, 2016 08:59 AM
