D.I.Y. Removing the intake resonator
Old Oct 20, 2007 | 04:24 PM
rbsurfer's Avatar
Ok befor i start im 16 so this is not HARD at all
First you want to remove the front bumper its only 4 bolts and a couple clips i circled them in red
Then under the hood remove the black plastic thing above the radiator then there is 2 more clips and thats it the front bumper comes off with just one or two firm pulls i found out it is alot eaiser to start on one side and work my way around
now put the bumper off to the side this is the resonator
and here are the only bolts holding it on
now when you remove the bolts just pull and dont be afraid of breaking anything. then there you go one removed resonator
Now just reverse the steps to put the bumper back on
Old Oct 20, 2007 | 04:52 PM
01tl4tl's Avatar
Check your year- my 01 had a small plastic connector piece that needd to come out along with the resonator box
It was easily added to the pile with a good yank of the channel lock pliers
Old Oct 20, 2007 | 05:57 PM
rbsurfer's Avatar
yeah it came out with it for some reason so i left it off i have an 03 tl-p
Old Oct 20, 2007 | 10:51 PM
jlammers's Avatar
thanks for the write up
Old Oct 22, 2007 | 12:28 AM
MurkyRiversTL's Avatar
COTM Coordinator
Its funny how you managed to take every pic from the same exact spot, almost as if you had it on a tripod or somethin....... oh yeah and nice quick write up
Old Oct 22, 2007 | 01:34 AM
2K3_TLs's Avatar
OMGWTFVTEC
but the quality is like cell phone-ish...
still, good writeup!
Old Oct 22, 2007 | 02:45 PM
rbsurfer's Avatar
i spent my money on the car not a camera it was from my cell phone
Old Oct 22, 2007 | 11:24 PM
Rsoetidjo's Avatar
Rich
Does it help with performance, gas mileage?
Will it throw any code?
Old Oct 23, 2007 | 02:43 AM
COTM Coordinator
Wise choice, cameras arent as fast as cars, and you cant really mod camera.... except for lenses, but why waste your money when you can spend that money on free mods like removing your resonator
Old Oct 23, 2007 | 03:17 AM
Juliet's Avatar
Littlest Pirate
u can mod some cameras. ive seen a few that can be hacked to run emulators on the view finder
Old Oct 23, 2007 | 06:06 PM
rbsurfer's Avatar
the first day no just really wacky because the computer was prob confused
Now it is alot cleaner and quicker throttle response
And no when just idle you can bairly tell the diff. but when you get on it you fall in love like when you first bought the car
Old Oct 24, 2007 | 12:47 AM
COTM Coordinator
well then.... I stand corrected. Thats actually kinda cool.
Old Oct 30, 2007 | 09:50 PM
yooformula's Avatar
6th Gear
very easy. thanks for the pics, helped out to know what bolts I was looking for.
Old Oct 30, 2007 | 11:47 PM
Rsoetidjo's Avatar
Rich
How long it will take the computer to get use to it?
I just did on my wife car yesterday.
Old Oct 31, 2007 | 07:22 PM
ecaf005's Avatar
thanks, your pictures helped greatly. will this cause me to fail inspection?
Old Oct 31, 2007 | 09:56 PM
01tl4tl's Avatar
no issue with smog or inspection- doesnt make any noise at idle
Old Oct 31, 2007 | 10:14 PM
00 acura tl's Avatar
Inspired
thx for the DIY you should post this in the DIY section or i think there is one already not sure
Old Nov 5, 2007 | 12:02 AM
iforyou's Avatar
You'll Never Walk Alone
lol its funny how your profile says your 27 but then your actual age is 16..jk..
nice writeup, finally something I am able to do!
Old Nov 5, 2007 | 09:12 PM
rbsurfer's Avatar
hahah its so no one comes after me!!!
rbsurfer's Avatar
only takes 2 days max to adapt
Old Nov 5, 2007 | 09:16 PM
rbsurfer's Avatar
they dont check the air box in inspection in de and it actually is basicly a comptech airbox if you think about same thing if you get the filter so if they ask in inspection tell them its aftermarket
Old Dec 5, 2007 | 02:45 AM
TLover8888's Avatar
instead of waiting for the computer to adjust, cant you just reset the computer by disconnecting the battery for 15 min or so and then reconnecting and driving the car right after??
Old Dec 6, 2007 | 07:44 PM
rbsurfer's Avatar
because that would be a waste. if u disconnected the batt u need a radio code and stuff and the ecu would still have to adapt to the change
Old Dec 22, 2007 | 12:37 AM
n1njai's Avatar
This works for a 99?
Old Dec 22, 2007 | 01:32 AM
01tl4tl's Avatar
gen2 cars can reset the ECU by pulling the clock backup fuse, or the remove the neg battery cable trick
Its time to clean the terminals anyway so its worth the battery method
If you cant enter a 5 digit code, you're too weak to drive!
Old Jan 6, 2008 | 02:13 PM
burnerjunky's Avatar
Registered Pimp
what socket sizesss do i need
Old Jan 6, 2008 | 02:47 PM
bwebbTL's Avatar
i had my car for a week when i knew i wanted to take out the intake resonator but i didn't want to remove the bumper so i took the finder will and unscrewed the few bolts that connect it to the front driver side corner of the bumper and bent it back to the wheel this gave me enough room to get my hand up to the two 12mm bolts with a 1/4 in drive. then i just gave it a few pulls and walla it came out. then i just put the part of the fender well back up and it was over.
Old Jan 7, 2008 | 05:40 PM
rbsurfer's Avatar
you dont need sockets i just used a set fo pliers
Old Jan 8, 2008 | 12:58 AM
Registered Pimp
o well, i got it off anyways with sockets. My car now eats small children
Old Mar 26, 2008 | 07:11 PM
red00tl's Avatar
Well, I tried this today but the bumper clips have become so brittle that I couldn't extract one without breaking it.
So half way through I decided to pull off as I didn't want to drive around with a bumper held by only 4 bolts.
I'll get some new clips first and then try again.
Old Mar 27, 2008 | 12:42 AM
red00tl's Avatar
Couldn't leave it as it was, so I gave it another try.
Took me 2 hours but finally managed to remove the lower resonator.
I ended up with 2 short clips that I forgot where they were from, lol.
I'll rectify that tomorrow. Garage was too dark.
Old Apr 2, 2008 | 08:12 PM
bassforburly's Avatar
6th Gear
Thumbs up Just did mine!
Boy that had to be the easist way to gain some Hp! Easy Easy Easy and sounds like you have a V-Tec now!!!!!
I recomend doing this to anyone who doesent want to spend the money for a cold air intake!
Thanks!
Old Apr 4, 2008 | 09:08 AM
kumar.'s Avatar
Sun☆Works FL
I didnt remove my bumper to take it off, all I did was remove the splash guard under the drivers side and reached up and removed it. Took about 10 mins w/o removing the bumper.
Old Apr 8, 2008 | 11:55 PM
LTLZack's Avatar
The beast within
Awesome
Removing the air resonator, works wonder. If you haven't done it yet, run out and do it, because you are gonna love it for sure. It gives my TL a nice growl about the same as cold air intake, and I can feel it pull harder, not to mention the sheer joy that it puts on my face again and again. So, it doesn't hurt. You can always put it back if you don't like it.
I got a sound clip coming up of the difference
Old Apr 24, 2008 | 11:33 PM
lopez819's Avatar
is the removal any different for a 99
Old Apr 25, 2008 | 10:56 AM
ACURA`TL`TYPE-$'s Avatar
i don't think so.
i did the same to my tl-s not bad at all, no need to remove the bumper.
but does it really help with performance?
would CAI do the same or more?
should i save the money instead?
Old Apr 25, 2008 | 12:45 PM
fsttyms1's Avatar
^ The TL-S has a smaller resonator than the TL-P. Its far easier and faster on the P to remove the bumper. Cut the bottom off the air box to allow more air to get to the filter and get a good K&N filter
Old May 1, 2008 | 12:11 AM
ye i got the K&N filter
Old May 13, 2008 | 10:04 AM
ecaf005's Avatar
removed resonator and passed nyc inspection with no problems. i'm currently using a K&N filter too...now, will this cause any problems with acura if my transmission dies?
Old May 18, 2008 | 11:06 AM
maniaC_99's Avatar
...advance...
i JUST finished doing it on my 99 tl p!!!
car sounds great!
btw, the trouble u would have to remove it
without removing the bumper is just ridiculous.
i would say, if u gonna do it, do it right. take the bumper off
