Place in Central Jersey for ATF fluid change?
I'm over in central Jersey near Old Bridge. Does anyone know someone or a place that will do a proper job of changing my transmission fluid, replacing the filter, and pressure switches?
06 Anthracite TL
I had a Goodyear shop that I trust do the work a couple of years ago- I printed out instructions from Azine regarding the switch replacement and had them do a 3x3 fluid swap. Really, any shop can do this if you're not able to do so (because of lack of knowhow, tools, or space). I brought them them the 3 x 3 procedure as well. It was $29 to do the switches and $89 for the 3 x 3 fluids with me supplying the ATF.
I live in Old Bridge and found a highly reputable and respectable mechanic in East Brunswick. Found him about 7 years ago and he has been my mechanic as well as the mechanic for some of my friends.
The shop name is Eric's Premier Auto Center. It's on Route 18 north located between Lukoil and Sunoco. Directly across the street Kohl's.
Eric and Tom will give you not only the best price but also the best service. These guys are highly knowledgeable and very very customer friendly. Tell him that Doug sent you. Phone Number is 732 238-8585.
mada51589
05-03-2022 08:54 PM
nanos
11-12-2015 08:41 PM
