Honda/Acura Mechanic in North NJ
Hi everyone
my name is Paul and i have been working for Honda and Acura as a mechanic for over 10 years
I am located in Clifton NJ
If anyone here needs any work done to their Honda/Acura .
I will be more than happy to help you out
I have a nice size garage at home that i work out of
Anything from Maintenance to Upgrades.
And if i cant do the work i will try to point you in thr right direction.
The following 5 users liked this post by acrdr:
Danny Kaplan (08-06-2018),
DeathMetal (07-21-2015),
DMZ (09-30-2014),
FuriousSam (07-31-2014),
guugoo (08-01-2014)
For a limited time only
Trans service $ 50
VTM-4 $ 50
Power Steering Flush $50
V6-Timing belt kit$ 450 (new timing belt ,water pump,drive belt,new coolant)
Trans service $ 50
VTM-4 $ 50
Hey everyone
I'm sorry i have not responded to any PM lately
I just had a new family member come into our lives ,Baby boy , so i have been busy with him and did not have any time to do anything else
Now its slowly getting easier so i will be able to do work in my garage
So if you guys are still interested
Let me know
Thank you
Let me know
Thank you
Super cool guy went in for a routine transmission drain and fill!! accommodated my busy schedule and didn't even get pissed off for me moving my appointment... will be going to him for any routine stuff for the car
Don't forget to pm about the rotors and camber kit!!
acrdr (06-19-2013)
It all depends on your budget
So finally came time to work on my wifes 04 MDX
with 186k on the clock
i did the following
t-belt kit with new tensioner
new radiator (started to leak on the bottom ) with new rad hoses
new front engine mount
valve adjustment with new spark plugs ,new valve cover gaskets
coolant cross over pipe gaskets (wasnt leaking but i figured with the manifold off it was easy access
new thermostat
cleaned out the gear on my starter (it was making noise at start up)
put in aftermarket trans cooler to by pass the radiator cooler
cleaned out throttle body and intake manifold from carbon build up
restored headlights
will post pics
i did the following
new thermostat
restored headlights
will post pics
Paul just completed the sooner than needed 105k maintenance for my 2003 Acura CL-S. (prepping for sale soon)
As well as headlight restoration/brake work/transmission fluid flush and other odds and ends he noticed and informed me about...and worked with me to take care of.
I highly recommend Paul and his work he sweats the details and does incredible work.
Some "clickable" pics below of my headlight restoration and motor maintenance.
hey paul
i got 78k on my 2009 acura tsx
i've just routinely changed the oil, oil filter, drain/filled the atf, new tires and new brakes so far while i've had the car.
i think i'm supposed to do a coolant drain too? i bought the fluid but haven't done it yet.
anything you recommend my car needs for maintenance?
hey paul
replace the radiator hoses ,over time they dry out (just a precaution)get that out of the way at the same time
cabin filter been replaced ?
whats good about those cars is that they have minimal maintenance.
check your front lower control arm bushings (compliance bushings ) the tear over time
