Honda/Acura Mechanic in North NJ
Hi everyone
my name is Paul and i have been working for Honda and Acura as a mechanic for over 10 years I am located in Clifton NJ If anyone here needs any work done to their Honda/Acura . I will be more than happy to help you out I have a nice size garage at home that i work out of Anything from Maintenance to Upgrades. And if i cant do the work i will try to point you in thr right direction. Thanks |
hi paul
For a limited time only
Trans service $ 50 VTM-4 $ 50 Power Steering Flush $50 V6-Timing belt kit$ 450 (new timing belt ,water pump,drive belt,new coolant) |
would you do custom exhausts?
How much to change my clutch spring? Or maybe the entire clutch master and slave cylinder?
Thanks for making yourself available to the community. Do you have a fender roller?
No i dont do any type of welding yet
So far i can offer dealer type of work at great prices |
I know this isn't exactly dealer type work per say but would you be able to install coilovers with EDFC controller?
How much for oil change?
Hey everyone
I'm sorry i have not responded to any PM lately I just had a new family member come into our lives ,Baby boy , so i have been busy with him and did not have any time to do anything else Now its slowly getting easier so i will be able to do work in my garage So if you guys are still interested Let me know Thank you |
would you be available to drive out somewhere to check out a car (for a fee of course)
my mechanic said my valves are bent but i want a second opinion before i proceed with those repairs. its a half hr drive from clifton |
Met up with OP to do minor maintenance, great guy :thumbsup:
Originally Posted by byomes
(Post 14517371)
Hope everything is good |
Do you do any body repair? Specifically front bumper? Needs to be buffed and repainted.
Super cool guy went in for a routine transmission drain and fill!! accommodated my busy schedule and didn't even get pissed off for me moving my appointment... will be going to him for any routine stuff for the car
Don't forget to pm about the rotors and camber kit!! |
Originally Posted by apinwp09GBTSX
(Post 14532543)
Don't forget to pm about the rotors and camber kit!! It all depends on your budget |
I'm Paul Too! Who does the best buyable J32 builds in the country Bro? Looking for 350+ horses for the street, 2001 CLS. TNX Hamblaster
Originally Posted by Hamblaster
(Post 14620228)
but if i come across anyone reliable i will let you know |
whats does your transmission service include?
Originally Posted by Elegant TYPE S
(Post 14631846)
trans service drain and fill service drain old fluid and refill with up to 3 quarts of honda ATF DW-1 fluid new drain bolt washer $50 If you want to do the 3x3 fluid change its $100 plus your fluid |
Paul is a great guy. He work on my Acura Legend. :thumbsup:
trans service is basically drain and fill your trans fluid with 3 quarts of acura dw-1 atf
So finally came time to work on my wifes 04 MDX
with 186k on the clock i did the following t-belt kit with new tensioner new radiator (started to leak on the bottom ) with new rad hoses new front engine mount valve adjustment with new spark plugs ,new valve cover gaskets coolant cross over pipe gaskets (wasnt leaking but i figured with the manifold off it was easy access new thermostat cleaned out the gear on my starter (it was making noise at start up) put in aftermarket trans cooler to by pass the radiator cooler cleaned out throttle body and intake manifold from carbon build up restored headlights will post pics |
Headlight restoration
1.Before 2.during 3.After |
some pics of engine maitnance
hi, looking for a mechanic for maintenance stuff for my wife's mdx. how much for an A1 service. i'm a couple towns over
Originally Posted by mkma05
(Post 14721252)
Paul just completed the sooner than needed 105k maintenance for my 2003 Acura CL-S. (prepping for sale soon)
As well as headlight restoration/brake work/transmission fluid flush and other odds and ends he noticed and informed me about...and worked with me to take care of. I highly recommend Paul and his work he sweats the details and does incredible work. Some "clickable" pics below of my headlight restoration and motor maintenance. http://thumbnails108.imagebam.com/29...5290682461.jpg http://thumbnails101.imagebam.com/29...3290682477.jpg http://thumbnails107.imagebam.com/29...1290682485.jpg http://thumbnails106.imagebam.com/29...1290682491.jpg |
Thank you for giving me the opportunity to work on your car
Congratulations on the baby boy :thumbsup:
It's really great to have a Honda/Acura mechanic offering their services to us here :nod: |
Hey paul, Just sent pm about schedule/appt
Hey Paul, I was planning on changing the DRL's, Fog lamps to HID and the Switchbacks to LED. I was wondering if you could do it and if so, let me know the damage. Thanks.
Just met up w Paul, great guy, def going back when i need some more work done
Merry christmas and happy New Year to all
Hey Paul, I sent you a PM. Happy New Year!
hey paul
i got 78k on my 2009 acura tsx i've just routinely changed the oil, oil filter, drain/filled the atf, new tires and new brakes so far while i've had the car. i think i'm supposed to do a coolant drain too? i bought the fluid but haven't done it yet. anything you recommend my car needs for maintenance? |
Originally Posted by The Dark Knight
(Post 14816757)
hey paul
i got 78k on my 2009 acura tsx i've just routinely changed the oil, oil filter, drain/filled the atf, new tires and new brakes so far while i've had the car. i think i'm supposed to do a coolant drain too? i bought the fluid but haven't done it yet. anything you recommend my car needs for maintenance? replace the radiator hoses ,over time they dry out (just a precaution)get that out of the way at the same time cabin filter been replaced ? whats good about those cars is that they have minimal maintenance. check your front lower control arm bushings (compliance bushings ) the tear over time |
105k maintenance
Hi Paul,
I have a 2003 TL-S. How much do you charge for the 105k mile service (new timing belt, water pump, drive belt, etc.)? |
Originally Posted by mif2112
(Post 14818876)
Hi Paul, I have a 2003 TL-S. How much do you charge for the 105k mile service (new timing belt, water pump, drive belt, etc.)?
For a timing belt ,water pump , drive belt , coolant $450 I also recommend replacing timing belt tensioner which is $100 extra parts only Best would be for me to look the car over |
pm sent
