Sprint PCS and Nextel merger
I was listening to the news the other day and they said that it was rumored that Sprint pcs and nextel might merge. When that happened the stock went up a little. Is it to late to buy some shares in Sprint. Will the stock go any higher once they do merge? I want to buy at least 100 shares going for $24.00. Any suggestions, thnx greatly appreciated
What your problem is?
historically the acquired company does well and the acquiring company does not do well on the exchanges.... If I was you I would buy more shares of Nextel and leave Sprint as is.... Sprint PCS has had problems in the past and this merger is favorable to Nextel more than Sprint PCS, since Nextel is the one bringing more to the table technology wise.... I predict Nextel stock to go a little higher and Sprint PCS to stay relatively unchanged....
and what if Verizon ends up buying them huh? Lot of things can happen, more info:
https://acurazine.com/forums/showthr...31#post2255031
Verizon did look at both the financials (primarily of Sprint PCS) and has decided to not make a bid for Sprint PCS.... primarily because the govt may have blocked it.... company would have been too big....
If the merger does go through, then both companies will retain their own names.... it appears that the deal is an all stock transaction, which yields little to no benefit to investors since the stock trade will occure regardless of the price fluctuation from this point forward.... (most likely because they will prevent the trade of the acquired stock.....
Sprint PCS goes after the average consumer (teenagers, young adults, etc...) Nextel is going after the business market with the two-way radio feature and the blue-tooth compability... regardless, it is going to have some major hurdles since the two technologies are not compatible with each other and other problems...
Retired playa
Originally Posted by indoMFP
Sprint PCS goes after the average consumer (teenagers, young adults, etc...) Nextel is going after the business market with the two-way radio feature and the blue-tooth compability... .
Well, I have to recant... Vodafone has cleared the hurdle so we may see Verizon Wireless go after Sprint.... could this be another Oracle, PeopleSoft fiasco???
handsom-hustla
11-13-2015 05:04 PM
09-17-2015 09:01 PM
