Money & Investing Learn how to get rich on the housing bubble and the bull market…
Multi Unit Question
Old Jun 2, 2015 | 10:26 AM
2012wagon's Avatar
Multi Unit Question
I had acouple of questions for anyone that owns a multi unit rental property (4+units).
1)Do you need a commercial GL policy to cover the property?
2)If you are using a RE management company (like I do for my townhome rental property), arethey charging a flat rate/% or due to the number of units is there additionalor per unit charges?
3)Forinvestment property purposes, does it still fall in the 25-30% down paymentcategory, or due to multi unit, more dp is required?
Any otheradvise/info would be helpful, as we are currently in the exploratory processfor a multi unit in AZ, NC or TX.
Old Jun 4, 2015 | 12:03 PM
KaMLuNg's Avatar
it can differ by county and local township requirements... in NJ anything more than 3 units is considered commercial...
depends on certain mgmt companies and if you want them to also look after the whole property. some just do per unit % cut of the rent... if they will have to maintain the whole property (i.e. lawn service, common areas, etc) they may charge you extra...
usually 30%+ depending on the lender and how many other investments you currently have debt for... if this going under your name or an LLC?
see answers above
Rachel Lu
Sep 27, 2015 09:53 AM
atsx1313
Sep 22, 2015 09:04 PM
tmux
Sep 21, 2015 05:11 PM
datadr
Sep 12, 2015 09:12 PM
