FS: TL slave cylinder with removed delay valve
For SaleDrivetrain
Price
$45
- Location Citrus Heights, CA, 95610, USA
- Condition Used
- Compatibility
Make | Model | Year |
Acura | TL | 2007 - 2008 |
Description:
This was removed from my 07 TL Type-S with around 120k miles. A dental pick was used to remove the circlip so the delay valve could be removed without grinding as some others have done. Honda urea grease was used on the Piston rod under the rubber bellow. A new Goodridge speed bleeder m8 x 1.25 is included with it.
My TL had a squeaky clutch pedal and it was the clutch master cylinder on the firewall. Being that I had to open the system I decided to put in a new slave cylinder along with the clutch master. I read about the slave modification on the forums. I decided to modify the original one first before attempting it on the new slave cylinder. A metal dental pick is all you need to remove that little C clip but it is a pain in the ass and that sucker will go flying if you're not careful. The speed bleeders are sold in pairs of 2 so I decided to sell this one to save someone the headache of modifying and bleeding it.
You are limited to two (2) Private Messages, so if you want to send or receive more you will have to delete some PM's to reduce the PM count to one or zero.
