FS: 2010 TL SH-AWD 6spd Mayan Bronze Metallic / Umber
For Sale2010 Acura TL
Price
$7,500• OBO
- Location Cleveland, OH, 44118, USA
- Condition Used
- VIN 19UUA9E50AA006885
- Mileage 114,000
- Engine 6 cyl
- Drive Type AWD
- Transmission Manual
- Vehicle Type Sedan
Description:
This is something I literally thought I may never do but I've decided it is what makes the most sense.
When Acura re-designed the TL for this generation, I fell in love. They paraded around a Mayan Bronze over Umber 6spd car to all of the shows and it seemed to me to be the perfect daily driver. I told myself that if I were ever in a position to buy one, I would do it. About 5 years ago I was tired of driving my lowered Cooper S convertible all year long in Cleveland. I realized that these cars were in my price range so I started looking for a super clean Mayan Bronze, Umber 6spd car... I eventually found this one in Indianapolis. It was the original owner (I'm 99% sure, I'll detail why later), with a complete service history and it was listed with about 67k miles. We settled on a price. A friend and I had one of the best mini roadtrips to get the car, stopping in Columbus for a night. When we got to Indy, slightly hungover, the car was better than I could have imagined.
Cut to the chase, Andrew, why are you selling it? Probably 6 months into my ownership I noticed that it was a little low on oil. High within the range, but low. I researched the problem and saw that a number of the J37s in these cars were replaced early, early on in their lives due excessive to oil consumption. I figured since this was such a slow burn rate, my car wasn't affected. I continued to keep an eye on it, religiously filling it when it was low. This past fall, I decided that I had had enough and the consumption had gotten to a ridiculous level. I started an oil consumption test with local Acura Dealer A. I really didn't like the vibe I got from the service guy there so on my way home I called Acura Dealer B to see if I could finish an already started test with them. They said yes. Great. 1,400 miles later I return to that dealer, they check the consumption and it's definitely excessive. They say, however, that I'll need to start a new test with them to have it all at one place. Ugh. They send me on my way and I drive to Detroit for the weekend. On the way back from Detroit I start noticing a tick from the valvetrain. I park in my garage that night and then call Acura in the morning. While on the phone with Acura, I check my oil to see that the dealer never refilled the oil. It was still in the "acceptable" range but not at a level that I ever would have driven 5 hours on the highway. To be fair, I don't think that the dealer leaving the oil low is 100% what caused this noise but I do contend that the noise is low-oil related and having it low during that trip highlighted the issue causing me to be able to hear it. The valvetrain in these engines, from the ones I've heard always seem to make some noise but this is now more than some.
Once I got the good news that Acura was going to replace the pistons and rings, I asked that the valvetrain be looked into to determine the noise. Acura will only consider covering a repair related to oil-consumption if there is a diagnosis done by an Acura dealer. Fair. And since the labor to remove the heads would already be done, it seemed to make perfect sense that they could check while they were in there. All parties agreed.
About 4 days into the dealer having my car, I get a call from the service manager. He tells me, good news, it just needs a valve adjustment. It'll be X cost. I say, awesome, I really appreciate you checking into it, go ahead and do the adjustment. 3(ish) days later I go to pick up my car. The service manager tells me everything is great so I happily grab my keys and go to my car. I leave the door open while I start it to hear a tick-free start. What happens? It's ticking. What else happens? The low-oil light comes on. I immediately shut the engine off and walk back to give them the news. They check and there is oil in the car. "The low-oil pressure switch must have gone bad". It was not bad before taking it in. I ask him what (if any) damage they found in the heads. Essentially, they didn't look telling me it would have been too expensive and taken too much time. So they found that the valves needed adjustment and just figured that was the issue. Not usually how a mechanic tackles a job, I'd say.
Problem is, Acura stands by what was done and says they can't force a dealership to spend time looking into this for me. The dealer has agreed to cover the labor for taking the heads off but I would be responsible for any time spent looking into the actual problem. That time will easily cost $1,200 and that wouldn't include the cost to repair what's wrong if Acura decides it's not their problem. Which definitely seems to be the case. I can't get myself onboard with the potential of spending thousands of dollars to find an issue that I have a high conviction I didn't cause and have to pay to fix it in the end.
Although I love this car, it leaves a bad taste in my mouth now every time I look at it.
So. The car runs and drives perfectly well and has no symptoms other than a rather noisy valvetrain. Because I rely on this vehicle for work and I have too many other projects I don't have time to tear into it, find and fix the issue myself. It kills me but I can't hit the road with no concern, so I have to cut ties.
I know this has been wordy, but I want to be 100% upfront and give potential buyers the full background.
The Good:
- Mayan Bronze over Umber - perfection
- 6spd manual
- SH-AWD
- 114k miles
- Pistons and rings replaced under extended warranty
- This was about 500 miles ago and it does not seem to be burning any more
- Valve adjustment 500 miles ago
- Timing belt done
- Service history from new
- It has been meticulously maintained by both me and the previous owner
- Technology package
- Awesome sound system
- Extremely comfortable seats
- Very nicely done DARK tint
- I 100% feel that this is the perfect all-around car. I've even auto-xed it once and it was a blast.
- The aforementioned ticking. For all I know, the next owner could dig into this and it becomes a non-issue, leaving me the real loser. Since I don't know what the problem is, I've just assumed it's bad.
- Bumps and bruises
- The first owner had a TV stolen from his garage and they dropped it on his trunk. Scratches and some little dents
- The first owner was backed into and the FL fender was painted
- I have the paperwork for this
- I was run into while driving in the left lane by a car pulling out of a stopped right-hand lane
- The FL fender, and bother driver-side doors were painted
- I was hit last fall backing out of a parking spot by lady who was flying and I never saw
- Technically this was my fault as I was the one backing out but she obviously felt at fault because she scrambled to get insurance...which was obviously rejected
- I have not had this repaired yet because I was waiting for spring but will certainly do that if the buyer wants. It'll cost me my $500 deductible.
- Various scratches that a daily-driven car will get
- Pictured these as best I could
- The paint could generally use a good detail. Typically at this point in the year I would have done this already but can't get myself to do it... I would be HAPPY to pay for a full detailing should that help this car go to a great new owner.
- Driver's seat bolster
- This is a common area of failure on these cars. I've seen a number of TLs with the vinyl (it's either vinyl or a MUCH thinner leather) completely missing. I've been able to keep the vinyl in-place by gluing from behind. Hard to explain but there is no gluey or hard texture. This same failure is in it's beginning stages on the passenger seat as well as the rear headrests.
- Some very minor interior scratches
- The low-oil light comes on every time you start the car now. The oil is not low. I'll get this replaced.
- It could use front brakes. I have the parts and will get this done before selling.
- I planned to put new tires on it before winter.
There really isn't enough good that I can say about this car which, considering the circumstances, seems strange. I think without the valvetrain noise, this would be an $10,000-12,000 car all day especially because of the color combination and manual trans. I'm asking $7,500. This is the top end of the KBB Trade-In range in "Good" condition. There is a price at which I'll just keep it, stick it in a storage unit somewhere and come back to it once I have time but don't tell my wife...
1. TITLE: Is it clean, clear,rebuilt, or salvage? If other, please explain.
2. Do you have title in hand or it is being held by a lienholder?
1. Title is CLEAN
2. Title is held by a lienholder - I owe very little on it and will pay it off once someone is buying the car.
