Notices
Free: Factory OEM 2017 -2020 MDX 20" Wheels. 42700TZ5B11, TZ520080A
For Sale
Wheels and Tires/Axles
  • Wheels and Tires/Axles - Free: Factory OEM 2017 -2020 MDX 20" Wheels.  42700TZ5B11, TZ520080A - Used - 2017 to 2020 Acura MDX - Los Angeles, CA 90067, United States
mellonc is offline
  • Price
    $0
    • Trade
  • Location Los Angeles, CA, 90067, USA
  • Condition Used
  • Compatibility
Make Model Year
Acura MDX 2017 - 2020
Description:
I would like to LOCALLY trade these factory OEM, 2017 - 2020, 20 inch wheels that came out of an MDX Sport Hybrid.  These are currently on a 2020 model car with 21K miles on it.  The wheels are clean and have zero curb rashes or scratches.
I would like to trade these for a clean set of OEM 18 inch wheels from model years 2017 to 2020.   Please no bent, damaged or repaired wheels.  Also no black wheels please.
Cost: $50 per wheel plus your trade-in of 18"s.
For the tires that are already on your 18's we can compare the remaining tread life on my current wheels vs. your current tires.  We can calculate the cost difference and make an adjustment.
Tire specs: (except for the diameter, they should be the same between the 20"s and the 18"s)
Lugs: 5
Bolt Pattern: 120mm
Offset: 55mm
Hub Bore 64.1mm
Logistics: Local trade only please.  I will drive to most of Southern CA locations to swap the wheels from my vehicle to yours.  You can Venmo payment after both parties agree on condition of wheels/tires and price onsite.
Old 09-28-2022, 11:44 AM
jaav's Avatar
Would you take any interest in 19's?
I've got a set of 19's - rare ZDX wheels. Tires I believe are 255/50/19 - but I'll have to confirm this since its currently stored in my garage.
ZDX RIM SPECS:
Lugs: 5
Bolt Pattern: 120mm
Offset: 45
Not quite local (Las Vegas) but a drive could be possible.
jaav is offline
Old 09-28-2022, 12:40 PM
mellonc's Avatar
Sorry. I'm specifically wanting 18 X 8's.
mellonc is offline
Old 09-28-2022, 09:43 PM
mellonc's Avatar
just answering a question about the tires on the wheel. These are Nexen N5000 Platinum with about 1000 miles on them. You don't need to purchase any new tires. All you need to do is to swap and you are on your way.
mellonc is offline
Old 09-29-2022, 12:20 PM
mellonc's Avatar
Price lowered to $50 per wheel plus/minus adjustments for swapping tire condition
mod edit-updated
mellonc is offline
Old 09-29-2022, 05:16 PM
Administrator
Ron A's Avatar
Received 1,003 Likes on 573 Posts
Do you still need the trade in?
Ron A is offline
Old 09-29-2022, 05:36 PM
mellonc's Avatar
Yes.
mellonc is offline
Old 10-19-2022, 04:59 PM
mellonc's Avatar
bump.
Now, the cost is $0.
mod edit-updated. Thank you!
mellonc is offline
