Toyo Proxes T1R's 235 45 17 With 17x9 Rims
Old Jan 17, 2019 | 09:15 PM
Winson C's Avatar
6th Gear
Hello everyone, I'm new to the wheels and tires. Im planning on getting Toyo Proxes T1R's 235 45 17 tires on my MB Battle 17x9 rims. Do you think the fitment will workout?
Old Jan 17, 2019 | 09:41 PM
horseshoez's Avatar
Latent car nut
What are the specs of the wheels you're planning on using?
Old Jan 17, 2019 | 10:18 PM
Winson C's Avatar
6th Gear
Im not sure whats my offset, all the original owner told me that it was 17x9.
Old Jan 18, 2019 | 06:27 AM
horseshoez's Avatar
Latent car nut
You'll need at the bare minimum, bolt spacing and offset.
Old Jan 18, 2019 | 12:21 PM
nats007's Avatar
I assume the wheels are already on your car... If so, then for 17x9, 235/45r17 should work. Many run 245/40r17 as well for a square fit. Some run 255 if you want the meaty tire look.
What matters is your drop and clearance within the wheel well to prevent rubbing/touching of the suspension components or fender liner. Knowing the offset would definitely help with that.
Old Jan 18, 2019 | 01:25 PM
Winson C's Avatar
6th Gear
The old owner went mia once he sold the car, I dont want to stretch out the tires because the tires right now is 215 which is really stretched. By the way the fenders are rolled. It should work if i lift my car higher too just enough.(Just guessing).
Old Jan 18, 2019 | 01:26 PM
Winson C's Avatar
6th Gear
BTW this is my car.
Old Jan 18, 2019 | 01:29 PM
nats007's Avatar
BTW this is my car.
Clean bro! Then I recommend you run 245/40r17 then
Old Jan 18, 2019 | 01:32 PM
Winson C's Avatar
6th Gear
Thanks, and Thank You everyone for helping me. Much needed. Im still fixing it up. Let me know if anyone have any new ideas to include.
ooze48
Oct 12, 2016 06:49 PM
Time For Sleeep
Jun 5, 2009 11:20 AM
KamikazeTL
Feb 27, 2009 12:42 PM
KamikazeTL
Feb 10, 2009 07:38 PM
lilvinnyb
May 5, 2007 01:42 PM
