RSX 2nd Gear Lag
Old Apr 14, 2011 | 08:02 PM
Qhab-Meem's Avatar
Question RSX 2nd Gear Lag
So i have an 2002 RSX Type S. I was driving it around and all of a sudden i was gonna step on it and in 2nd gear it would go no more than 4 thousand rpm it was like a rev limiter. So do you guys have any clue what the cause could be?
Old Apr 14, 2011 | 11:00 PM
Qhab-Meem's Avatar
Help anyone?
Old Apr 15, 2011 | 12:59 AM
ParaSurfer1979's Avatar
Have you checked your oil level?
Old Apr 15, 2011 | 06:48 AM
Qhab-Meem's Avatar
No, but could that be the cause?
Old Apr 17, 2011 | 10:56 AM
Jeff122886's Avatar
Jeff
4kprm limiter means the car is in limp mode. usually happens when you have a check engine light. do you have a light on? also check engine oil level like others have said
Old Apr 17, 2011 | 10:07 PM
Qhab-Meem's Avatar
Yeah, my check engine light is on. The reason for that is cause the O2 sensor is bad which means it needs to be replaced. Plus I looked a the oil level one morning and i didnt see anything. Then i started it up and took it for a spin around the block and came back to look at the oil and wiped it and put it back and I noticed there was nothing on it. So what now? I REALLY NEED HELP!
Old Apr 17, 2011 | 11:00 PM
Just as I told you it would be. Where was the oil level on dip stick b4 you went for a drive? This is very important.
Old Apr 17, 2011 | 11:08 PM
Qhab-Meem's Avatar
i didnt see shiet! but the thing is this car has been sitting for a few months too tho. plus i added enough b4 it was sitting too tho. thats wierd how it could just dissapper like that.
Old Apr 18, 2011 | 12:27 AM
Get an oil change. You may have an oil leak who knows. Id change the oil anyway. That old oil in an engine that hasnt been running for a while isnt good. You should always turn over the engine every now and again. You could have always been low on oil when you 1st sat the car for that period.
Old Apr 18, 2011 | 11:56 PM
Rocketright's Avatar
Yeah it wouldn't be because of a bad 02 sensor, it doesn't go in limp mode for that.
Take it to a shop and see what codes it throws out.
Old Jun 2, 2011 | 11:13 PM
Krazzyie's Avatar
change the oil and ask the mechanic. Im thinking it could be because of multiple reasons
Old Jun 6, 2011 | 09:20 PM
pickler's Avatar
hmm i got this problem on my 2G Tl sometimes. I was trying to pass someone i think i was going about 50mph and i floored it but rpm was at 4k and climbing very slowly?! no CEL, No oil issues, no leaks. changed tranny fluid yesterday and still problem exist sometimes.
Old Jun 7, 2011 | 11:44 AM
Thats really odd.
Try resetting your ECU.
To do this just either (A)Unplug your battery for about 15 minutes, (B)Remove the ECU Fuse in your fusebox for about 15 minutes.
Then after that simply put your key in for about 10 seconds, then start it. Don't press the gas pedal at all, and just let it sit for about 10-15 minutes and let it idle.
If it's in your ECU that might help you. I have to reset mine every now and then because me CEL comes on with my Racing Header in winter.
SidhuSaaB
May 30, 2020 12:40 AM
Jul 16, 2017 07:33 AM
RSpyder
Sep 30, 2015 12:46 AM
