Please help! I need to pass emissions in VA
Old Oct 21, 2011 | 06:19 PM
paky786's Avatar
I've been trying to get emissions done here in VA and for some reason it won't pass on my 2002 Acrua RSX Type-S with 40k miles on it
There used to be a turbo in the car but I had it removed and the guy before me had this stupid device (Apexi SAFC 2) in the car and my car isn't passing emissions. I tried to mess around with the SAFC settings but now the car jerks and it's running rich most of the time.
I don't know how to work this device and I just want to remove it now. Can I just disconnect it in order to try and get emissions done?
I have new cat in there, exhaust system, aftermarket intake, one new o2 sensor (there are two), also has a fuel booster line under the car..what could be wrong, Any idea?
Old Oct 21, 2011 | 07:52 PM
ParaSurfer1979's Avatar
Needs to be tuned on a dyno with a mechanic...
Old Oct 29, 2011 | 10:47 PM
tsxykid105's Avatar
in the apexi there should be a base map somewhere in the menu or in there and make sure you have a cat. since it was turbo you mite not have one which youll need to get one then. but look around in the device and try to fine a base map but when you go for a inspection they dont drive your car so they wouldnt no. all they do is check outside and then plug in an obd2 scanner and check everything so id also go to an auto parts store and rent a scanner and see if you pull any codes and fine out what they are. good luck
joflewbyu2
Oct 8, 2015 11:16 AM
MilanoRedDashR
Oct 2, 2015 10:49 AM
kb1rl
Sep 30, 2015 10:17 AM
hrothgar02
Sep 28, 2015 11:08 AM
rangomango
California
Sep 24, 2015 05:47 PM
