Help! Headlight.
Old Nov 28, 2011 | 07:06 PM
Mara's Avatar
Help! Headlight.
Hello! I have an '06 RSX and I just found out the clip is broken in my drivers side headlight. (the bulb won't stay firmly in place without it) An Acura dealer priced $500 to replace the entire housing + labor. Any other options? Any spots to get cheaper headlights or a way to fix it for cheaper? Any advice would be helpful. Thanks
Old Nov 30, 2011 | 12:11 AM
knavekid's Avatar
Acura Fanboy
Check Ebay for replacement headlight assemblies. I bought a pair for my '02 RSX for under $200 shipped. There are several styles, but they likely won't match the originals exactly so both should be replaced.
Old Dec 17, 2011 | 04:31 AM
C25A1guy's Avatar
I can divide by zero
If you're speaking of the X-clip (H1 bulb sits in it and the H/L harness plugs into it), you should be able to get it as a separate piece. The retaining clip is a different story and is not available as its own independent piece, however if times are tough (and I know how tough they can be), you can take a piece of wire coat hanger, cut and shape to length and it should be an ok fix until you can get the housing replaced.
pistacio
Sep 26, 2015 09:45 AM
Soyboy26
Jul 31, 2007 07:32 AM
krazy99cl
Feb 21, 2006 08:42 AM
eighteight
Oct 21, 2004 07:42 PM
