RSX DTC P1457 EVAP issue
Old Feb 18, 2022 | 01:01 PM
Nickchr99's Avatar
4th Gear
HELP! 02 rsx base k20A3
The car keeps throwing the same evap code (p1457) I’ve replaced the canister itself, the shut off vent valve on the canister, I replaced the evap by pass solenoid that’s on the other side of the canister, I replaced the purge valve on the throttle body, IACV, gas cap, and im still getting this evap leak code.
…also got the ECM checked
and everything is good there
Old Feb 18, 2022 | 01:56 PM
EE4Life's Avatar
Forum Contributor
See the following TSBs:
TSB 02-032 - MIL Comes On With DTC P1457
Applies To: 2002 RSX – From VIN JH4DC5...2C000001 to JH4DC5...2C024017
http://www.urvi.net/forumfiles/SB/B02-032.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/B02-032.PDF
TSB 08-010 - MIL Comes On With DTC P1457
Applies To: 2002–04 RSX – ALL
http://www.urvi.net/forumfiles/SB/B08-010.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/B08-010.PDF
Old May 23, 2022 | 01:49 PM
Nickchr99's Avatar
4th Gear
Help p1457
2002 Acura RSX base A/T:
Can anyone help me get to the end of this code. I’ve replaced a lot of parts of the EVAP system and I’m still getting this code.
parts I’ve replaced:
-gas cap
-purge valve
-charcoal canister
-shut off vent valve
-two way by pass ( on the other side of the canister)
- fuel tank vapor vent
-fuel tank pressure sensor
-hose from the canister to the tank
is there anything else that can trigger this code?
Old May 31, 2022 | 12:55 PM
18TLXAspec's Avatar
Did you rule out TSB 08-010? If not, may need to replace the fuel vent tube..if you haven't already.
Old Sep 15, 2022 | 12:34 AM
Nickchr99's Avatar
4th Gear
Engine light p1457
After replacing all EVAP components , from gas cap to fuel tank vapor vent, I keep getting this p1457 code & was wondering if I could have zapped my PCM. The code will come back on after a good 200-300 miles and kinda seems during foggy weather
Jamus22
Jan 4, 2017 09:22 AM
poisx7
2G CL Problems & Fixes
25
Dec 26, 2016 11:37 PM
johnpancakes014
Jul 17, 2015 07:18 PM
vdiddy210
Aug 8, 2009 07:05 PM
arm5262
Dec 12, 2008 08:58 AM
