Broken driver's side lock
Old Dec 14, 2011 | 11:46 PM
Haley Burger's Avatar
3rd Gear
The lock on the drivers side of my 02 RSX won't respond to my remote key. I have to manually unlock the drivers side, then click the remote which will then unlock the passenger door and the trunk. I have a feeling it is just jammed. Is there an easy way to take off the door panel? I have tried once before, but can't find one easy way to do it...
Old Dec 16, 2011 | 07:45 AM
knavekid's Avatar
Acura Fanboy
If you do a web search on Ab0VE Acura RSX Service Manual (Ab0VE with zero instead of O), you should find a version of the RSX service manual that you can download. This will have instructions on removing the door panel and replacement of the door lock actuator.
Old May 30, 2012 | 04:54 PM
Nadster's Avatar
6th Gear
I have the same problem and just wondering if "jammed" is the problem. is it a quick fix or is it more complicated.
rockyboy
Aug 4, 2024 10:35 AM
jblessing
Aug 8, 2018 09:43 PM
acura_dipset_tl
Jan 1, 2016 03:02 PM
PortlandRL
Sep 14, 2015 12:01 PM
coykiam
Sep 11, 2015 03:43 PM
