Transmission pan mishap
Hello all,
So, after 60,000 miles of waiting for the transmission fluid change code to come up, I finally decided I was going to change the ATF in my ILX dual clutch transmission. I decided to buy a fluid transfer pump that screwed into the quart bottle. It worked fine and I had pumped out a little over 4 quarts into the transmission pan in a very short amount of time. However, the "bummer" was that I had decided to spend about 3 more dollars on a fluid pump that had a little plastic gadget that was supposed to "help" hold the plastic tube in the fill hole. Well, the tube kept slipping outwards and I tried to position the plastic piece further in. It actually went in a little too far... Of course as I tried to pull it back out the plastic fitting decided to take a dive inside of the transmission...Its about an inch and a half long, hollow and maybe about the thickness of a pen or pencil. (I was on my back in the driveway and having some trouble accessing and seeing the fill hole as I worked)
Does anyone know if this plastic piece is just going to "hang out" in the transmission pan around a filter screen or get into a bunch of mischief throughout the system as it tears, brakes or melts?
The car is running fine, but it's quite a downer not knowing what might happen...
I've done transmission fills successfully on Civics and Mazda's and never had this kind of a mishap before. I followed all the relevant instructions and it ruined an otherwise perfect diy project.
Any helpful advice or comments would be greatly appreciated.
Thanks in advance,
Water
Thanks in advance,
Water
1Lieutenant
4G TL Problems & Fixes
Aug 24, 2012 12:03 PM
yaze21
1G TSX Problems & Fixes
Dec 30, 2009 09:08 AM
