Accuracy of info on dash
Hey everybody, I have a question about psi on the tires and oil level, I just got my tires
changed 2 1/2 months ago and the PSi
is different on all four tires is this normal? And if not what should each one be? Here’s a picture of what’s on my dash. Also it shows oil life 30% after I got it changed not long ago, is that accurate. I’d really like to know what each one of my tires psi should beAnd why they’re all different after just getting new tires not long ago.
check with a tire pressure gauge
Thanks, but that doesn't answer any of my questions. I am not a "car guy" so talk to me like I am slow....when I put air in my tires ( I haven't since I got 4 new tires) I go until it meets where it is supposed to be, the machine stops automatically,lol
What PSI should each tire be?
Should they all be different as shown in the picture and why would they all be different that soon after new tires?
Why would oil life be 30% a month after getting a change?
As for the oil life monitor, are you sure it was reset when the oil change was done? If so, how many miles have you driven since then?
There's a sticker at the drivers door jam that says the recommended tire PSI. Use that as a reference to adjust what ever machine you are using to put air in the tires. Second, like mentioned above outside, temperature can cause the psi to rise or drop 3-4 psi depending on how cold it outside and how hot you get your tires (Given you're not doing burn outs lol). Third, you might have a bent wheel that's causing the tire to not seal well to the rim and could be leaking air. As far as your oil % dropping down that much in a month could be an issue that only a dealer can solve or someone forgot to reset it and you didn't pay attention.
