16’ ILX on waffles
16’ ILX on waffles
I’ve had a few suspension/wheel arrangements since taking ownership in 2015. Finally settled with the H&Rs on some TL take-offs. Oem+ look is just cleaner than my prior pair of rpf1s (imo) and the ride quality is much more bearable for Orlando daily driving (whole city is under construction...always).
EvilVirus (04-17-2019)
evmans (11-07-2019)
stickers are gross but otherwise looks aite
evmans (03-24-2020)
they really make the car scream "i'm a juvenile", super clean otherwise..
evmans (09-17-2020)
evmans (09-17-2020)
evmans (09-17-2020)
evmans (09-17-2020)
Thanks - The spacers are Dynofit hubcentric 5x4.5 20mm M12x1.5 64.1. Fenders are slightly rolled, but occasionally rub due to +size rubber/switching back to coils. The muffler is just a 2.5" downturn off the stock piping.
godfather2 (03-26-2021)
Sold the 16' and picked up a 1st Gen with the k24z7/6mt. Haven't done much yet, but really liking this platform. Currently on Skunk2 springs/Truhart shocks and running a 3.5" Ktuned SRI w/ Ktuner.
The following 2 users liked this post by evmans:
godfather2 (06-17-2021),
visi_d (06-11-2021)
S2 manifold installed, running the PRL Motorsports RBC swap adapter kit. Upgraded the lower mount to a Hasport 70a as well. Would've swapped it far earlier had I known how dramatic the improvement would be over the stock mount. Everything feels tighter, smoother, and more responsive.
Currently waiting on a few additional goodies to arrive:
-AP2 S2k Wheels (in keeping with the oem+ theme), pieced together a full set of fronts in great condition
-Hasport upper mount
-Acuity short shifter
visi_d (09-27-2021)
Pulls like the previous gen si up top, but with considerably more torque than an 8th gen on the low/mid end. Sounds great, but Is definitely in need of a comprehensive tune. I'm still running the K-Tuner base map while I look into e-tuning options. Installed with the PRL manifold and TB adapter which seemed like the easiest route, but it was still a bit of a hassle to sort out the air intake fitment and wiring to the maf sensor.
I swapped both the factory upper and lower mounts (Torque Solution 75a upper/Hasport lower) at the same time I installed the RBC. The mounts offered the most significant improvement of any bolt on to date - traction, shifting, handling all greatly improved.
justnspace (09-27-2021)
evmans (09-27-2021)
K-tuned crash bar arrived this past Friday.
Not even a day later on a nearby street...talk about timing.
Not a single scratch to the oil pan or other downstream components underneath. Well worth the peace of mind.
evmans (10-05-2021)
I know, typically try to avoid brick roads at all costs but didn't have a choice here. $140 for the bar vs. replacing that oil pan was a no brainer. Might pick up another just to have a spare should k-tuned discontinue it.
visi_d (10-05-2021)
evmans (12-07-2021)
anionrings
3G TL Photograph Gallery
20
12-07-2012 05:20 PM
