Do I have ELS radio or Not?
I need help understanding which radio I have. I have a base model 2.0 with Premium Sound System.
Is this the same as the ELS 10 speaker system?
Im asking because I just noticed the spec sheet paper that came on my car (whatever its called....it's on the window of each car at the dealership)
Anyways....that sheet says: ACURA/ELS Surround Sound and it also list SiriusXM Satellite.
Problem is, I dont have XM Satellite in my car like it says it does on the spec sheet with my VIN number listed.
What should I do?
What should I do?
Deyon22... I do not think you have the ELS system (I would imagine your radio head unit will have the ELS designation if it did). There is 3 levels of stereo for the ILX. Base; Premium; or ELS. The ELS system has more speakers and can be easily determined by looking in your trunk - If you see 3 speakers you probably have the ELS system, if you do not see any speakers especially the 8" woofer in the middle of the deck lid then you do not even have the Premium stereo .
The ELS System will have a slightly different 8" woofer, 2 additional rear deck speakers, and a larger amp under the upper foot well area of the drivers side. Usually the ELS system also comes with the ILX versions with the GPS system/larger infotainment screen.
What should I do?
What should I do?
any thoughts on this?
It’s the ANC (active noise cancelling), you can delete It by removing the glove box. There is a little module that you disconnect.
What should I do?
What should I do?
thisisnotdave
28
Aug 11, 2018 01:05 AM
mercman
47
May 31, 2015 06:00 PM
ostrich
Oct 8, 2014 08:20 PM
Stehlin Mitchell
Oct 17, 2013 08:01 PM
