Removing reflextors
Old Mar 13, 2019 | 09:10 AM
angelrmc's Avatar
6th Gear
Removing reflextors
Hey all, new to the forum, and Acura world, and need help. My used 2016 ILX got dinged in the parking lot. I got the ding smoothed out, but I need to paint. Anyone know how to remove the reflectors and trim on the back bumper?
Old Mar 13, 2019 | 09:17 AM
easiest way is to remove the rear bumper; which then will reveal the clips that hold in the reflectors...
or you could just lay underneath to look for the clips that hold the reflectors....
Old Mar 13, 2019 | 09:38 AM
angelrmc's Avatar
6th Gear
I was under the car, removed all the plastic clips to access the spot, removed the one screw that I saw, but it still would not budge. I don't want to damage it by prying, I only see one screw.
Old Mar 13, 2019 | 10:12 AM
perhaps this helps?
Old Mar 13, 2019 | 12:00 PM
DaIll1's Avatar
There is one screw and 7 tabs (around perimeter) holding them on. You must remove underskirt to access the inside of bumper.
When unclipping tabs, it's easiest to start at the pointed end near the screw (the top 2 are the most difficult). Good luck!
Old Mar 13, 2019 | 01:23 PM
angelrmc's Avatar
6th Gear
Thank you! I will be working on this tonight. Do the tabs have to be pushed down then I assume? Toward the center of the reflector? Any tricks you can give to help?
Old Mar 13, 2019 | 05:50 PM
DaIll1's Avatar
The insert is less flexible than the bumper, but I would suggest warming the bumper. If you try to flex a frozen bumper, it will break.
I used a wide bladed screwdriver and placed between the insert tab and the bumper tab and twisted while pressing outward on insert tab.
Here's a close shot to help
TheyGotMawty
Feb 20, 2017 05:59 PM
Freshjive360
Dec 10, 2009 01:29 PM
HiHenry.com
Dec 17, 2007 08:10 AM
NateBoozer
Jan 11, 2003 10:52 AM
