MT: Gear shifting
Old Jul 24, 2014 | 10:35 AM
In2itioN's Avatar
MT: Gear shifting
Hi guys. After a bit of research I figured I'd start a new thread because I can't find anyone who seems to have the same (problem?) as I have.
On my 2014 ILX 2.4 MT, I used to LOVE how fluid shifting gears was. It was like a knife through butter and every gear was very precise. With time however, shifting gears has become less obvious: When I shift from 1 to 2, the shifter always gets "stuck" in the perpendicular center track (kinda hard to explain but the crossroads to go towards higher gears). 2 to 3 is good, 3 to 4 as well, but 4 to 5 is systematically a pain and 5 to 6 is hit-and-miss.
Has anyone experienced something similar? Is it possible that the specific way I drive has worn the transmission and that's what makes a bit sluggish?
Any insight is warmly welcome.
Old Jul 24, 2014 | 12:28 PM
OSUBeaver's Avatar
5 to 6 is never great if you're anything under 3000 rpms, and especially if you lay off the gas pedal when you shift. I try to get on it a bit more on that shift and it's smooth every time. 1 to 2 is similar, the higher the rpms the better it shifts. These higher compression engines shift best above 3K, that's my 2 cents after 8 months of driving. Try a day of not shifting below 3K and see what you think
Old Jul 24, 2014 | 09:25 PM
duce2k's Avatar
I hit that 7k red line daily when shifting, if you're not used to shifting at such high revs it feels weird and takes awhile to get used to
SidhuSaaB
May 30, 2020 12:40 AM
Jul 16, 2017 07:33 AM
joflewbyu2
Oct 8, 2015 11:16 AM
mellsonnj
Sep 24, 2015 04:42 PM
