ILX suspension noise
#281
I believe he, or someone else posted that the part numbers are different from the 2013 to 2014.
I would most definitely assume whatever is causing the sound is also causing a change in the way they perform. Hopefully not causing damage though but if so acura should replace anything and everything once they solve the issue.
Shocks are just the housing, with basically a simple oil pump inside. It is hard to imagine where the sound originates from... especially without me having heard the sound.
If it a loud sudden THUNK that lasts like a second or is it long and drawn out?
If it takes a second Id think the chassis or suspension are hitting something.
If it was long and drawn out then Id assume it is more the shocks themselves... maybe having improper hydraulic fluid pressure.
IN a long speed bump, as explained when people say they hear the sound, the body tends to travel less in relation to the wheels and axle. With a narrower speed bump the suspension travel will be much great.... this further confuses me because if you ask me Id assume a long speed bump creating sounds would be due to hydraulic fluids where as if it was a narrow speed bump that causes more suspension travel could be the chassis knocking on a suspension component.
Hope my rambling can help the discussion further.
#282
#284
#286
SHOCK ABSORBER ASSY., RR. - 2013 ACURA ILX (52610-TX6-A05)
SHOCK ABSORBER ASSY., RR. - 2014 ACURA ILX (52610-TX6-A06)
http://www.dchautomotiveparts.com/oe.../52610-tx6-a06
I believe those are both the Rear Right... A05 and A06
I wonder what the difference is.
#287
2013 front shock 51611-TX6-A04
2014 front shock 51611-TX6-A05
2013 rear shock 52610-TX6-A05
2014 rear shock 52610-TX6-A06
Source: Honda themselves.
#288
I beleive this is the front and rear for both 2013 & 14. Please correct me if i'm wrong.
2013 Front
51611-TX6-A04 SHOCK ABSORBER UNIT, R. FR.
51611-TX6-A05 SHOCK ABSORBER UNIT, R. FR.
51621-TX6-A04 SHOCK ABSORBER UNIT, L. FR.
51621-TX6-A05 SHOCK ABSORBER UNIT, L. FR.
2014 Front
2013 Rear
52610-TX6-A05 SHOCK ABSORBER ASSY., RR.
2014 Rear
52610-TX6-A06 SHOCK ABSORBER ASSY., RR.
2013 Front
2014 Front
2013 Rear
2014 Rear
Trentimus (05-28-2013)
#289
Here is the complete front & rear Shock Absorber Assembly comparison side by side for the 2013 & 2014 ILX.
Not sure why there were two part numbers available for the FRONT, left/right side (highlighted) for the 2013 model year.
Maybe you can purchase the new 2014 part for the 2013?
#290
Attached is an updated spreadsheet of the 2013 & 2014 front and rear shock absorber assembly.
As you can see (highlighted), based on the part numbers; the 2013 front has an option for the newer 2014 shock absorber.
#291
Update
I got the rear shocks replaced with the "new" 2014's, which have the different part numbers.
Result - I'm hearing the same damn noises/thumping No difference at all.
The stock shocks/struts/dampers on this car are complete garbage.
#292
If you got them replaced how can you blame them. Its clearly something else.
#293
Wow.
Okay. Your ilx is making a noise and you figured its the strut.
You swap out Strut A for Strut B but the sound remains. A mechanic worth their weight in greasy work button ups would tell you its not the damn strut.
usdmJON (07-01-2013)
#296
My ILX now has 6500 miles on it. Just got done doing a 3000 mile trip from Vegas over the Rocky's to KC then back through OKLAHOMA into Santa Fe NM and then back to Vegas, all kinds of roads. Guess I've been lucky so far no noise??
#297
haha, best response ever. Yea, I'm lucky I don't have noise. I plan on getting the hfp suspension so I won't have to worry about any of this noise who-ha. Also, this car with a bigger sway bar (which I have) and spring/shock combo will make it a competent handler.
#299
I do hear something from the back upon occasion. It does sound like spare tire cover but it doesn't happen that often so I don't think about it when I do have something in the trunk. Seems to do it if I go over a man hole cover that is not flush with the pavement but only at an angle at speed if memory serves me. Doesn't happen that often so I consider it a non issue at the moment.
I don't hear anything from the front at all.
#300
Hello. I just bought my 2.0AT in April and brought it back to the dealership in Springfield, NJ for the thumping noise when the car goes over bumps and other imperfections and also a constant annoying rubbery clunking noise. They claim to have heard the same noise and allegedly replaced the rear struts which resolved the issue. Wrong!!! this noise is getting on my nerve and so is the hard riding rear end. Did you or anyone else get a resolution? I regret downsizing from my 10 TL due to the gas prices.
#301
The suspension noise, whether some of us have faulty struts and along with the road noise that they call "normal" is TOTALLY UNACCEPTABLE for a car Acura is proud to call "luxury.
I'm going in again tomorrow, now for 6th time related to the same damn unacceptable noises on this $30k "luxury" car that I can bet a $14,000 Kia Rio doesn't sound like.![Why Me](https://acurazine.com/forums/images/smilies/whyme.gif)
Has ANYONE had a resolution from Acura personally with this?
#302
I'm in Northern NJ, but I got the car at Montclair Acura.
#303
Looks like my car got the fix...Will write later in detail what was done but looks like the rear end got a makeover...arms, links etc....
#304
Good luck on the resolve. Happy to hear there was some headway, at least with one poster.
#306
Waiting very impatiently to hear the whole story and how your dealership is more competent than the two I've dealt with repeatedly for the past year, with no end in sight, and tons of frustration.
#307
^can you try calling his service department and apprising them of your problem? Perhaps they'll fix it for you?
#308
Do you really think it's incompetence on the part of your dealer(s) or just more information/experience is available now? From a dealers perspective, (admittedly not service dept) they need Acura HQ to identify and engineer a fix and in the meantime (from your reports), they've done all you've asked. The mechanic is probably being paid a flat rate of .5 hours to spend a half or whole day working on your car.
#309
Where is the disconnect here?
#310
I really wish I could tell you. But as noted, I don't have the problem and our store hasn't had any customer with it as you describe. I haven't checked on bulletins, but service is closed today for a state holiday.
I wish I could offer some solace for you as I can see how frustrated you are with the situation. I'm just out of ideas. Is is possible that you hear something that I also hear but consider it "normal"? I've been wondering if you have a broken weld somewhere in the unitbody?
#311
1: Front passenger-side knocking: At low speeds (see engine mount thread). Apparently I am not the only one experiencing this noise since there is a tech-line summary print-out, which indicates there were trying to diagnose the problem for someone else as well.
2: Rear thumping: Any dip in the road, man-hole.....Plenty of reports on this, not an isolated issue.
How can it possibly be "normal", or a broken weld, when many others have reported the same and a poster just said that his dealer diagnosed and fixed the same issue for him by changing: arm, links....?
#314
It's very simple Colin (nothing personal). I'm experiencing both problems on a daily basis since day 1.
#315
We arent mechanics working for acura. We arent going to be able to help with your problem. Period.
Its a new car with new issues. Youre at the mercy of the dealers and if they dont see YOUR problem as a detriment to their sales then they wont see your issue as a priority.
Users are trying to give advice where we have the amount of knowledge as you; zero and youre arguing with them incessantly.
And the recent claim to having a fix was just a claim. I dont think the user has even driven the car yet. They just witnessed some changes the shop did AND they didnt even specify if it was a dealer or shop.
THAT being said. How dare that user leave you guya hanging like this. Thats what happens when users arent as technology prone or just the drive to be apart of a community. Help these people out!!
#316
In the end. I have no idea why youre still driving the same ilx. I would have driven to the dealer and told them I cant stand the knocking and want a new ilx or I will switch dealers TODAY. Claim a breach of contract because they arent fixing the issue and youre still under warranty. Demand a new car or you will get on social media networks and highlight your grievance with acura and that specific dealer.
Ruffle some feathers, bends some fingers back. In the end dealers see selling cars as the hard part. Make it harder for them!
#317
2013 ILX Suspension Noise
I have a 2013 ILX with Tech Package. Its making a noise when i go over bumbs or holes! Dealer doesnt know what what is it yet. I posted it on youtube. kchow101 or kchow101@hotmail.com
#318
![Thumbs Down](https://acurazine.com/forums/images/smilies/thumbsdown.gif)
#319
For whatever it's worth, from the RDX forum, regarding the same thump they are hearing on their cars.
Revised Rear Wheel Shock Absorbers Installed!
Yeepee!!!!
Took my vehicle into the dealership yesterday and had the new rear wheel shock absorbers and interior wood grain appearance package installed. No more clunking noise from the rear. Yeepee!!!! Vehicle drives super smoothly now. So happy I got this done.
Thanks everyone for creating a forum on this topic. Its unfortunate this happened but I'm glad people spoke up about this. Much appreciated. It will sure help a lot of people with the same problem.
Super stoked!!!!!
Later everyone
Yeepee!!!!
Super stoked!!!!!
Later everyone
#320
