front brake torque specs?
2015 acura ilx base
looked online and in the forums didn't find a 100% answer just maybes
i do know the lug nuts are 80 ft
not sure what the 14 mm on the caper are
and if there is any more what are the specs for that? the 17mm thanks!!!!!
This is for the 2.4L ILX, NO ENGIBE SIZE PREF WAS GIVEN.
Brake Caliper Torque Application/Qualifier Caliper to Bracket (Ft.-lbs) Bracket to Knuckle (Ft.-lbs) Front Caliper Rear Caliper Front Caliper Rear Caliper w/2.0L - - 80 55 w/2.0L 25 17 - - w/2.4L - - 80 55 w/2.4L 25 17 - - Copyright © 2012 by Motor Information Systems, a division of Hearst Business Publishing, Inc. All rights reserved.
Brake Rotor Qualifier Position Max.
Parallel
Variation
(Inches) Max.
Runout
(Inches) Nominal
Thickness
(Inches) Discard
Thickness
(Inches) w/2.0L R .0006 .0016 .354 .315 w/2.0L F .0006 .0016 .906 .827 w/2.4L R .0006 .0016 .354 .315 w/2.4L F .0006 .0016 .984 .906 Copyright © 2012 by Motor Information Systems, a division of Hearst Business Publishing, Inc. All rights reserved.
Brake System Bleed Procedures (W/ ABS)
Bleeding Sequence:
- Left Front (1)
- Right Front (2)
- Right Rear (3)
- Left Rear (4)
Bleed Procedure:
Aftermarket Approach- OEM Did Not Supply
Special/OEM Procedures
Brake Lining Thickness Qualifier Location Min. Pad
(Inches) w/2.0L Front .063 w/2.0L Rear .063 w/2.4L Front .063 w/2.4L Rear .063 Copyright © 2012 by Motor Information Systems, a division of Hearst Business Publishing, Inc. All rights reserved.
