Differences between years.
Hey guys,
this is my first post on Acurazine, but I promise I've used the search button and have been reading up on stuff before I posted this. I was wondering if someone could help me narrow down the differences between the 13,14,15 ilx. Specifically the 2.4, I currently have a 2013 si, but am looking to step up in classiness and swap my mods to the ilx. I just want to know what small changes were made throughout these years. Thanks!
Hey guys,
usdmJON is correct, as far as power train goes. They all use the same K24Z7 motor.
If you have mods on your SI and looking to jump into a 13-15 ILX then you're in luck. Almost all engine parts and some suspension parts are interchangeable.
Wish that was possible with the 2016 ILX. I can't even get an intake on my car.
Aside from I supposed the recall on hybrid/base halogen lights. So the hybrid/base ILX changed from 2013 to 2014. Headlight insides only. Nothing cosmetic.
But the 2.4 ILX in the states, as well as the Dynamic in Cananda, and as well as the Premium, and tech everywhere all had zero changes between 2013-2015.
They changed a lot in 2016. But the 2013 2.4 ILX and the 2015 2.4 ILX are identical cars.
What did Honda do? They panicked and rushed out a redesign in Nov 2012 for the 2013 model year.
The Civic again saw updates in 2014, but these updates/changes were for its MMC (mid/minor model change) refresh. Honda always offers updates/changes during the middle of the car's life, just like how the ILX saw updates in 2016, so this update was expected unlike the 2013 "emergency refresh."
You have to realize that the Civic received so much attention and got the updates and changes in such a short period of time because it is one of Honda's bread and butter cars. The ILX (along with the RLX) is Honda's red headed stepchild.
When the Civic sells 15 to 18 times more than what the ILX does in a year, where would you focus your attention and priorities?
Good to know, Thanks everyone for the responses. I just figured they wouldn't let the civic out-class the ilx per say in areas like the blind spot camera and change in stereo.. Guess I was wrong! hopefully I'll be picking one up relatively soon and can contribute more to the forums.
They are all different years though so to flashpro a 2015 ILX may as well be a damn jetski. The ECU are identical but since it is in a different year ILX, and the computer can see that, it wont work. Even though the maps would be identical as well fuel to air ratio. It just wont work due to the limitations hondata puts on their products.
This is interesting.. So people who have the 2015 wont be able to use Flashpro? I have it for my si and would be planning on swapping it over so that's pretty important to me.
Flashpro limits how you can use their unit as I tried to highlight in my last post.
You can use your flashpro on another civic as long as it is the same exact year, same exact trim, and in the same market... as in a flashpro for the US market civic will not work for a civic marketed for canada, china, japan, etc etc even if it is the same exact car aside from where its sold.
In order to use your flashpro on another civic you would first have to have your ECU flashed back to stock to allow the flashpro to flash different ECU. But your civic's flashpro will NOT work with the ILX of any year.
Your best bet there would be to sell the flashpro and use that money to buy a new one for the ILX.
Im pretty sure that is incorrect, as my flashpro says 2012+ civic si / ILX specifically on it. but maybe there is something I am missing regarding that. I know I would have to flash the civic back to stock.. but after that it SHOULD be transferable.
You can not use the same flashpro unit on a civic and ILX even if that year ILX has a flashpro available.
Well... Id say they are all the same. But you are right about flashpro.
Just giving This guy a heads up before he makes a mistake and realizes all the mods he wants to use are pointless because he can't tune. get a 13 or 14 if you can find one you like, will be limited for awhile/ maybe forever if you buy a 15.
My suggestion is to email Vit who will have a 100% correct answer for you.
My claim is that you cant even use a USDM 2012 Civic SI flashpro on an EDM 2012 Civic SI; let alone a Honda flashpro for an Acura. I understand its the same car. But as k24ilx just said. Its all in the computer programming.
Installing a civic exhaust on an ILX works because the bolts and layout pattern wont suddenly stop working if the exhaust reads "wait I belong in a 2013 and this is a 2015". The computer system will do that and it will not work. EVen though it should work and its all identical. It wont work until Flashpro puts money into R&D to say it does work then actually forks over the effort to remarket it.
Hondata is looking at the numbers they got from producing a 2013/2014 unit and decided it was not worth it for them as NO ONE is modding their 13/14 k24 ILXs. When I say no one I mean no one is tuning. Maybe like 5 have in the world. That's not worth it to hondata.
What I suggest is to contact OTHER tuning/race groups and see who can get a stand alone unit working or knows another option.
Try Ktuner. They have flash but from what Ive heard here it doesnt support larger injectors or a turbo yet. Push for Ktuner to allow that support. I'd put money on ktuner developing something before hondata decides they'll actually make money off a unit for the 2015 now that the 2016 is available.
Well if you want to get TECHNICAL they may be the SAME ECU but they have Different ECU/Part numbers so physically it may be the same but digitally it is different. I bought a 15 and found out i couldn't use a flash pro after the fact.
I was just replying with the thought that I had stated the cars were identical. They are identical. The flashpro should work. But youre right it wont. This limitation is not because the ECUs are inherently different but because they have two different years in their coding and that coding prevents the flash from taking in the newer ECU.
Literally all hondata has to do from a technically stand point is change the coding to allow for the year stamp "2015" and it'll work exactly the same as the 2013 and 2014. But this would require time, money, and man power. To which hondata doesnt like using very often. That's why tuners like Vit came out. 3rd party maps on Hondata units FTW!! Vit can put more time into that segment than hondata is willing to. I suggest talking to Vit OP. He should have all your answers.
k24ilx (09-21-2015)
To my understanding it for sure will not work with the 2015 as there is no unit for the 2015. As for it working with the 2014 or 2013... I am not sure. What I do know is your flashpro would not work with an EDM Si which to me seems more similar to the USDM Si than the USDM ILX does.
Who are these other two users? Why are they not here?! Lol
Cant wait to see what you do with an ilx. When did you plan to buy?
Thats awesome. So youll have to buy a 13 or 14. Not bad. No differences between the 14 and 15 yo justify the need for a 15. Hell i like the number 13 and enjoying owning the first year model. Though i guess im lucky cause everyone expected more of us would see year 1 issues. I havent.
Im not sure the ILX is even sold in Japan.
I may be wrong here but I believe its just the American, Canandian, and Chinese markets with it.
China would be the place to buy since it has the clear turn signals NO ONE here has.
Sorry, I should've clarified. Ill be buying one in the states but it will just be waiting for me in storage while I'm in Japan.
Can anyone tell me based off this link is there anything that a 13 ilx wouldn't have that a 14 would?
Acura | Certified Pre-Owned ILX Model Year Comparison Page | Acura.com
I know it says available for some things like heated seats and power seats but then standard in 14. Does anyone know if the 2.4 got those options in 13?
Try getting a Canandian 2.4 dynamic. Only available in cananda. It's a 2.4 with all the tech bells and whistles. Only a couple here can say they have a 2.4 with tech package.
The 13 2.4 is a premium in the US so it should have whatever the premium ILX is listed to have. I do believe you have heated seats.
I don't know how easy it would be to get a 2.4 dynamic. I'll look into it though. Thanks for the info though, hopefully I'll have a build thread before long.
No youre completely right it wont work and that is indeed something OP should be informed about.
Still trying to convince hondata to get it going:
https://www.hondata.com/forum/viewto...p=84540#p84540
