Anyone else running android 4.4.2?
Old Mar 26, 2014 | 10:26 PM
sumo_ilx's Avatar
Just did a system update on my note 3 and notice my text msg function no longer works on my 2.4.
Anyone else experience this?
If I click phone, im no longer even able to access text msgs.
I have tried to unpair and repair my phone. No luck.
Old Mar 26, 2014 | 10:40 PM
Rickards's Avatar
Same issue here. Samsung Galaxy S4, 4.4.2 and no more text messaging function.
Old Mar 27, 2014 | 09:51 AM
rrl31762's Avatar
Been running Android 4.4.2 on my Nexus 5 since I purchased it last November. Works just fine with my ILX text messaging sync.
Old Mar 27, 2014 | 01:16 PM
sumo_ilx's Avatar
humm weird... I'll play around with some settings.
Old Mar 27, 2014 | 07:08 PM
k24z7's Avatar
4th Gear
HTC One on 4.4.2 and I don't get texts either... Music streaming and calls work fine tho .. odd
Old Mar 27, 2014 | 09:01 PM
Zonian22's Avatar
I did the update on my LG G2 and it worked just fine afterwards. Although the first time I connected after the update the phone asked me if I wanted to allow the bluetooth device (ILX) to access my messages. I just responded yes.....and no problems yet. The only problem I have is that Pandora will not auto-start like before. I have to physically turn on or press play on Pandora via the phone everytime I get in the car. I'm still looking for a fix to that.
Old Mar 27, 2014 | 11:02 PM
sumo_ilx's Avatar
Do you know where you can adjust that in the settings?
Old Mar 29, 2014 | 08:02 AM
Zonian22's Avatar
Go into settings. Then, go into your Bluetooth setting. Then, under Paired Devices, click on the settings of your Bluetooth device (HandsFreeLink). Then, you should see three options (Audio, Media, and Messages), make sure they are all check-marked as being on.
Note: Make sure you're phone is connected to ILX when you do this procedure, if not connected, you won't get all the above settings for some reason.
Hope this helps.
Old Mar 29, 2014 | 03:00 PM
VckPtl's Avatar
On a different topic...iPhone users feel gutted that they cannot respond to texts or use the SMS feature, including myself. Even more demoralizing, iPhone users, along with Base owners, are ineligible to even use the Siri Eyes features. Rant over...
Old Mar 29, 2014 | 07:59 PM
sumo_ilx's Avatar
Strange. My phone only shows audio and media...
Old Mar 29, 2014 | 10:24 PM
FRST4DR's Avatar
Text messaging is working fine for me, I have a Samsung S4 on 4.4.2. Maybe delete pair from radio and phone and try again?
Have the same problem with music on my phone via Bluetooth. I have to hit the setup button on the radio and select pause/resume for it to start playing. Sometimes it will auto play but most of the time it won't and have to select pause/resume. At least with that I don't have to get my phone out.
Old Apr 3, 2014 | 02:20 PM
aksilx's Avatar
I did the update to kikkat on my sony z1 earlier this week and noticed that the BT keeps dropping and connecting on its own.
no issues with streaming music or sms
Old Apr 3, 2014 | 02:36 PM
sumo_ilx's Avatar
weird. So I called samsung support and they are unsure either.
Maybe it's just a note 3 issue? Altough that sounds weird...
Is there a updated in the ILX's CPU maybe that needs an update? I purchased my ILX in November of 2012 so it is one of the earliest models.
Old Apr 3, 2014 | 04:07 PM
aksilx's Avatar
try pairing another device to the ilx, if the sms works the problem is most likely the note.
Old Apr 14, 2014 | 03:11 PM
Barbie's Avatar
I have to purchase a new phone and I'm wondering if there is one particular brand or model of phone that works better with the ILX than the rest? Any suggestions?
Old Apr 14, 2014 | 03:16 PM
Colin's Avatar
The most consistent experience is with an iPhone. I know people love to hate them but there NO variance in your experience with this vs. Android. Text message functionality (through the Acura interface) is not supported through the car, but you could use Siri Eyes Free to read and respond to messages so no loss.
Old Apr 14, 2014 | 03:37 PM
usdmJON's Avatar
^truth
But I hear your iphone locks when it is plugged in...? This is true? Is it true for bluetooth?
Im using a Galaxy Note 2 so I dont have 4.4.2 but my texting interface and bluetooth work flawlessly.
Old Apr 14, 2014 | 03:47 PM
Barbie's Avatar
I had a Samsung Galaxy II but it didn't stay synced. Every time I got into the car I had to delete the phone and reconnect. I simply want a phone that will work every time and all functions will operate as they are designed to do.
Old Apr 14, 2014 | 07:42 PM
Colin's Avatar
Originally Posted by usdmJON
^truth
Yeah, when plugged in with the dock connector you will get an "Accessory" screen locking out a lot functionality. My solution is to play audio through Bluetooth and plug in via cigarette adapter if I need a little power.
Old May 1, 2014 | 09:49 PM
cm18cam's Avatar
Incoming Calls
So I am also running Android 4.4.2 and every time I go to answer a phone call through the Bluetooth in my ilx it automatically transfers it to my phone. Has anyone else had this problem or know how to fix it ?
Old May 2, 2014 | 03:54 PM
xdtownx's Avatar
My Iphone does the same thing
Old May 4, 2014 | 03:35 PM
Rickards's Avatar
Re-paired my phone and now I get text messages again, but it's delayed by like 10-20 seconds. Better late than never I suppose, but I'll let the dealer know the next time I swing by the dealership.
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
blacktsxwagon
Oct 27, 2015 10:12 PM
navtool.com
Sep 25, 2015 05:15 PM
