Temperature Threshold for an LCD TV
Old Jan 27, 2008 | 02:53 PM
phil2's Avatar
has Gloryhole Girls in
I am looking to put an 42in lcd tv out in my 3 season room so I can watch tv in the hot tub. Although the room is insulated very well it is not heated all the time. I am just wondering if I only use the tv when it is say 50+ degrees or just having it in there when its say 35 degrees will I damage it in anyway?
Old Jan 27, 2008 | 03:04 PM
sho_nuff1997's Avatar
I disagree with unanimity
it's prolly not recommended as per the manual, but i don't think it will hurt it.
i would think the steam from the hot tub would be worse.
Old Jan 27, 2008 | 03:17 PM
NetEditor's Avatar
Big White Chocolate
50 degrees Fahrenheit is about as low as is recommended. Low temperatures will affect response time and brightness apparently. So really low temperatures will affect performance but not necessarily longevity, so if the TV is just sitting there, it should be OK.
The big danger is humidity. Is there an exhaust fan in the room?
Old Jan 27, 2008 | 03:31 PM
phil2's Avatar
3 fans I am installing
Old Jan 27, 2008 | 07:20 PM
phil2's Avatar
I don't think the temps are an issue. I am sure they don't get delivered in climate controlled trucks.
Old Jan 27, 2008 | 07:33 PM
Scrib's Avatar
Administrator Alumnus
But over time, I think you're likely to damage the electronics. And when watching when it's 40 and steamy... Condensation.
Old Jan 27, 2008 | 07:41 PM
NetEditor's Avatar
Big White Chocolate
At 50 degrees, no. At near freezing, yes. If, for instance, you get a display delivered in really cold weather, I've heard you should allow the display to get to room temperature before turning it on. If, say, it's zero degrees outside, and the delivery truck comes, you don't want to get it inside, immediately take it out of the box and fire it up.
Old Jan 27, 2008 | 08:05 PM
doopstr's Avatar
Found this... http://www.lcdtvbuyingguide.com/lcdtvcaring.shtml
And yeah I always let electronic devices settle to room temp before turning them on. We used to get a ton of laptop failures at work until I told the morons to stop leaving the laptops in their cars' trunks.
No real way to get around the temp issue with automobile electronics though. That probably explains why the LCD screen on my car's radio is shot.
Old Jan 27, 2008 | 09:03 PM
phil2's Avatar
I agree, but for 650 bucks for it....I feel its disposable.
Old Jan 28, 2008 | 11:37 AM
soopa's Avatar
The Creator
then why are you asking for our opinions?
Old Jan 28, 2008 | 12:07 PM
Scrib's Avatar
Old Jan 28, 2008 | 09:03 PM
phil2's Avatar
I want to gauge its lifespan.
Old Jan 29, 2008 | 04:44 PM
2001AudiS4's Avatar
You say the room is not heated all the time? Do you turn the heat on a while before using the room? This would allow the tv's temp to raise to room temp at least. Take a look at an outdoor tv set, see if it works better for you. I have no experience with those sets, so I am not speaking from experience here.
rockyboy
Aug 4, 2024 10:35 AM
heykosal
1G RDX DIY & FAQ
Nov 16, 2020 03:59 PM
Scottyknows007
Sep 21, 2015 01:03 PM
CostcoFanAUS
Sep 18, 2015 06:05 AM
Sep 17, 2015 09:01 PM
