Plasma Wall mount
Old Apr 18, 2007 | 09:12 AM
llJrockll's Avatar
Rebourne
Plasma Wall mount
I have a question, I have a 42" Plasma TV which I've had for a while on a regular TV stand. I'm lookin' for a different look and would like to have it mounted on the wall. Now my question is would a 90lb plasma TV hold in place by being mounted on drywall? The last thing I want to do is buy a wall mount and have it fail on me because of the cheapy drywall.
I'm looking to get this Omnimount from CC.
http://www.circuitcity.com/ssm/OmniM...oductDetail.do
Give me your input guys....
Thanks,
J
Old Apr 18, 2007 | 02:54 PM
doopstr's Avatar
For any plasma mount you need to drill into the studs, and ensure that your screws tap into the center of the studs. Just randomly picking a spot on the drywall to put the screws with not be strong enough to hold the screen up.
Old Apr 18, 2007 | 07:25 PM
2001AudiS4's Avatar
It's moments like this that I realize why I have a job
Old Apr 18, 2007 | 07:27 PM
doopstr's Avatar
Do you send a drywall guy a day ahead of you to fix the wall?
Old Apr 18, 2007 | 07:31 PM
2001AudiS4's Avatar
Old Apr 18, 2007 | 08:35 PM
brianlin87's Avatar
ASM I.S. Design FTW.
Old Apr 19, 2007 | 07:11 AM
yuhoo22's Avatar
John Starks - The Dunk
At least you asked the question before you tried to do it....
Its pretty simple, all you need is a stud finder, a level, a drill, and maybe a ratchet/wrench and you should be good.
Old Apr 19, 2007 | 07:41 AM
doopstr's Avatar
I thought that maybe you have been called to fix failed installations by the homeowner.
Old Apr 19, 2007 | 08:41 AM
llJrockll's Avatar
Rebourne
Sorry for such a noob question, I guess as long as I have it clamped to a stud, I should be fine.
Wow, I actually found it for a cheaper price by searching online.
http://www.digital1234.com/product.jsp?x=U3FIXED
Old Apr 19, 2007 | 09:30 AM
soopa's Avatar
The Creator
priceless.
Old May 1, 2007 | 09:09 PM
hypertech's Avatar
I've got the tilt omni mount for my 50" plasma. The lag bolts are freaking huge. You are definitely going to want a stud finder to make sure you drill in the center of the studs. Mine came with a real nice template you stick to the wall when making the mounting holes. It even had a little dust catcher tray. Getting it super level isn't critical since you can compensate with the brackets that bolt to the TV fairly easily.
You may also want something like this:
http://www.monstercable.com/power/pr...r.asp?pin=2764
and to run your cables through the wall too for a nice clean look.
Old May 1, 2007 | 10:09 PM
2001AudiS4's Avatar
It is 100000 times easier to level the plate on the wall. Omni mounts are popular, but not my favorite. Sanus is definitely the way to go IMHO. Also, that monster thing is a ginormous waste of good old hard earned cash
Old May 2, 2007 | 09:27 AM
hypertech's Avatar
It does need to be close to level, but if you are off by 1/8 of an inch its no big deal.
I wanted some sort of surge protection for my TV and I didn't want cables hanging off the TV. The monster thing met my needs and I'm happy with it.
Old May 2, 2007 | 03:01 PM
2001AudiS4's Avatar
Surge protection is certainly important. I believe money is better spent on a whole house surge suppressor though. To each their own though.
Marcelechka
Home & Garden
188
Sep 11, 2022 11:53 AM
08KBP_VA
Oct 22, 2019 01:55 PM
Jul 16, 2017 07:33 AM
