LCD to DVR to DVD-R Wiring question....
Excuse the way I'm going to explain my situation below. A lot of you are much more knowledgable about this stuff than me, nor do you plan on coming to my house to troubleshoot it, so i'm going to be as clear as possible to explain my predicament.
I have my Samsung LCD TV that I recently purchased (Love it, btw). I have connected to the TV via HDMI the FIOS DVR, and a combination DVD-R/VCR (w/ 1080i upconversion)that is also wired to the TV via HDMI. I also have my Wii connected to it, but that's not an input in question to what my problem is.
I have the FIOS DVR connected via HDMI input #1 in the back of the TV
I have the DVD-R/VCR connected via HDMI input #2 in the back of the TV
To watch something on the FIOS DVR, I need to change the video input to HDMI input #1
To watch something on the DVD-R/VCR, I need to change the video input to HDMI input #2. I can not watch something on live TV when the video input is selected to HDMI #2, only watch whatever i'm watching on DVD or VCR.
My old setup before I got the LCD was a standard TV wired to a DirectTV box connected to the DVD-R/VCR. I was able to watch TV with the video input selected for the DVD-R/VCR, as well as record shows as I would need to. But none of these were connected via HDMI, only via S-Video or RCA input.
Now with the DVR I no longer have to record shows I want to see with the DVD-R/VCR. BUT I recorded something that I have saved in my DVR and I want to burn onto a DVD through my DVD-R that I want to save for future viewing. With it only connected to the LCD via HDMI it's not picking up live TV, only letting me watch whatever I pop into the DVD or VCR. What do I have to do to get the DVD-R to record whatever I'm watching on the screen?
Lastly, I have the program recorded on my DVR in HD. My DVD-R has 1080i upconversion, so does that mean it will be able to record the HD show? Also, if the answer to that questions is yes, will I be able to put the recorded DVD into a standard DVD player connected to a TV that might not have HD and still be able to watch it?
Pardon my ignorance, but this is one of my biggest weaknesses...I'm a dummy when it comes to this stuff....
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
The Third Ball
Received 4,911 Likes
Someone can correct me if I am wrong.
But I do not believe you can record from your DVR to a DVD-r. You CAN get specific software for your computer (i dont know which) and record the show off the DVR to your Computer (and then you could do whatever you want with it)
If you COULD copy from your DVR to your DVD-R and the show was in HD, the show would be down converted to standard definition somewhere in the recording process.
Not a ton of help, but maybe a little explaination
Big Block go VROOOM!
Because Of You
This is easy. You just run an extra SVideo cable ,and the red and white audio cable from the DVR to the DVD Recorder.
So,
1) the DVR outputs to both the TV (HDMI cable) and DVD (3 cables).
2) the DVD outputs one cable to the TV (HDMI).
This may not work with your DVD if your DVD doesn't have any video pass-throu. My Toshiba has the pass-throu. Any input I use, the Toshiba converts the signal and outputs to the HDMI cable.
So,
Big up ya self, BO!
I don't know too much about recording, but I do know that you can't record HD content on a blank dvd disk. HD material takes up a lot more space than standard def, so HD data won't fit on a dvd. Blu-Ray and HD-DVD disks have a much larger capacity than dvds, so they can fit HD content and higher bitrate audio tracks on the disk.
So,
So,
Also FYI, the DVD-R/VCR that I have is also a Toshiba, I forgot the model number, I think it's the
D-VR610 (http://www.tacp.toshiba.com/dvr/prod...?model=d-vr610) or
D-VR660 (http://www.tacp.toshiba.com/dvr/prod...?model=d-vr660).
I'll also check that tonight (i'm at work now).
Thanks!
So,
So,
I plugged the SVideo into the DVD-R/VCR's Input and the DVR's output and i'm not getting the video. I plugged a yellow cable into the DVD-R/VCR input and into the DVR Output and i'm getting video now (But I didn't disconnect the SVideo cable, even if I do I still see video because of the yellow RCA's). I am now able to see and hear live TV through the LCD's HDMI Input of the DVD-R/VCR. I don't know why the SVideo isn't working...
Did I do it right?
Oh, and also I have the Toshiba D-VR600 (Click for specs), not the others I posted above.
I am able to record live TV, I just recorded a few seconds of the show my wife is watching. I then started playing what I had recorded on the DVR and it also recorded that. Now all I have to do is play the whole show of what I recorded in HD, make sure it fits on the DVR-RW disc, finalize it and play it on another regular DVD player on a TV that doesn't have HD to see if it will work.
Because Of You
Yes, this is correct. The S-Video pass-thru only works when the Toshiba is on. The yellow RCA cable will go through the Toshiba to the TV whether or not the Toshiba is on or off.
I think you need to go to setup and tell the Toshiba whether to use the yellow RCA or the S-Video to tape the TV.
Big up ya self, BO!
Big up ya self, BO!
9 times out of 10 this is true. But when you start talking nuts and bolts though you can't arbitrarily say that HD content doesn't fit on a standard DVD. It all depends on the codec and bitrate used to encode the video. For example, I can fit a decent amount of 1080p video from my camcorder on a standard DVD. I still need my Blu-Ray player to play it back in HD though.
My camcorder doesn't actually record onto DVD. It's a flash-based AVCHD camcorder. All I have to do is take the file/directory structure off of the SDHC card and burn it on a regular DVD. I can stick that in my Blu-Ray player and away I go. I can get about an hour or so on a regular single layer DVD. The overall point here is that the video is just files and data like anything else. Certain things just need media with different minimum capacities to hold them.
Acura604
20
08-05-2017 12:55 AM
SUPRMN84
10-07-2015 09:46 PM
