DVI to HDMI?
DVI to HDMI?
If I want to hook up a computer to an HD set... can I use a DVI to HDMI cable? I know HDMI is touchy so I want to make sure I can use it before I buy the TV.
The Samsung I am looking at (LN-R328W) http://www.samsung.com/Products/TV/L...NR328WXXAA.asp
Has a PC input, but its RGB-15/RD-15 not DVI... but it has 1 HDMI input... other alternative is S-Video...
Big Block go VROOOM!
I'm completely guessing here, but I think the key is making sure that the computer's video card and associated driver are capable of outputting the resolution and signal timings that are needed by your TV. I'd recommend browsing the HTPC forum at AVS.
If you can answer yes to these questions... then you'd be in good shape with a DVI/HDMI cable....
Yeehaw
I have a DVI-HDMI cable running from my pc to my HDTV. Haven't figured out the widescreen alignment yet, but as far as the signal goes, it works fine.
dɐɹɔ ǝɥʇ ʇɐɥʍ
On topic, when I was shopping for a long HDMI cable I found more HDMI-> DVI and DVI->HDMI cables then I did regular HDMI cables.
navtool.com
31
11-16-2015 08:30 PM
AcuraKidd
09-25-2015 11:18 PM
navtool.com
09-25-2015 05:15 PM
