Wiring house (RG6 & RJ45)
Old fart
So I bought a house about a month ago... The previous owner had cable to each room on the 2nd floor (3) and one in the basement. And he's got ethernet to two of the rooms upstairs and to the basement. I decided to figure out which cable from the basement goes to which room...
The guy had cable from the outside to a 3 way splitter... from the 3 way splitter, he had one to the cable modem, one to I still have no idea where and the other to a 4 way splitter. From the 4 way splitter, one goes to the master bedroom, where it's split again to both cable jacks in the bedroom
And another from the 4-way splitter to a 2-way splitter for the other two bedrooms.
I just got cable before lunch today so I'm going to check to see how weak the tv signal is to those rooms...
Ethernet was run to two of the rooms upstairs and to the basement. As I was checking out the wiring to one of the bedrooms, I found that the guy spliced the ethernet cable and reconnected it to another piece...sitting right next to one of the 2-way cable splitters
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
So long story short, since the basement is finished and does NOT have a drop ceiling...is it safe to pull RG6 wiring through the air return ducts? Or do I need special rated stuff like Plenum RJ-45?
I'm kinda also thinking about using some combo cables, but have no idea if they are safe for pulling through air return ducts: http://www.impactacoustics.com/produ...=201&sku=43077
Any suggestions, ideas are very welcome
Just wait till somebody buys my house
. I had the installer confused as hell and had to draw him a number of pictures about how I wanted it to work.
he swore it wouldn't work .... but it works exactly as it is supposed to. I feel bad for the guy who has to figure it out later ....
dɐɹɔ ǝɥʇ ʇɐɥʍ
I'd bet it was a "trained" installer who f'ed everything up. The tech's that come to install cable, internet, etc... are typically one generation from knuckle dragging and do the quickest, EASIEST thing they can to get in and out. Most people don't know any better and could care less. I've made it a habit of tipping these people, you'd be amazed at what a 5 or 10 spot will do for your install and level of service you get.
...or the guy who lived there before you is a fucktard who spends to much time at ratshack.
I am about to enjoy wiring my house for network and phones. I have a crawl space, so I will just drill up through the sill plate into the outside wall, then put combo phone/network plugs in the wall.
Originally Posted by Scottman111
Sounds like this guy was a professional huh
I have some stuff pulled through ducts, I never really figured it would be a big deal ![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
Old fart
are there plenum rated coax? Or do I just have to find other means of pulling my cable lines?
I think the guy did it himself cause the cable company wouldn't even help my friend fish wire through his house...and he doesn't even have a finished basement...
Originally Posted by mt6forlife
Yeah until there's a fire. You're supposed to use plenum rated cable because when it burns, it won't emit toxic gas like burning PVC will.
SUPRMN84
10-07-2015 09:46 PM
